Soap vs detergent for Front load washer
lassie
Mar 2, 2017
4
British Columiba
Hello. I need to wash two outdoor "high-performance" coats which are water and wind repellent. One made of 100% polyester, the other 90% poly, 10% elastane. One says to use powdered detergent, the other says "soft soap". In the past, similar garments (e.g. Gortex) say to use soap, not detergent. However, with the advent of front load washers, one is cautioned to always use HE detergent. Can anyone suggest how I go about cleaning these garments in my front-load washer? I wonder if Dr. Bronner's Pure Castille Liquid Soap would work as it is low-sudsing, but I'm not sure how much to use. Thank you.
I use Lux Soap Flakes when washing Wool or down in the front loader. I dissolve in boiling water and and add through the dispenser whilst its filling. I've used up to 3/4 a cup of flakes on a gentle cycle without coming to grief before.
Just dont use it all the time as you'll get soap build up.
Over here, Miele have a product for washing Outerwear that works quick well and supposedly doesnt damage the waterproofing, I use that on my Gortex items.
That's interesting brisnat81. Lux soap flakes are not available in Canada; possibly even North America. However, i did find other pure soap flakes available through the internet. One site in particular offered lots of information and a long list of applications.
FLs don't like suds because suds lack the density for the pump to get ahold of them.  And the low clearance between inner/outer drums allows suds to regenerate during spin.
Um, you know those 'exploding' washers?  The "fix" involves attaching a sticker saying NOT to wash water repellants.  Water won't spin out, gloms in folds/pockets, throws balance off catastrophically.
Believe if I had water repellants needing washing I would do it by hand in the bathtub, take it to a professional laundry, or at very least CLOSELY supervise the machine during operation.
According to my research, the "exploding" washers were top-loaders only; no front loaders were recalled. Nevertheless, best to err on the side of caution when washing unusual items in any washer and as arbilab suggests, keep a watchful eye on the machine.
Thanks man114; I will check out Atsko sports wash.
Sportwash
Taiga Works in Vancouver has or did have Nikwax Tech Wash, says revitalizes breathability and water repellency,cautions against regular detergent for Goretex et all. Used it several times. Currently have new bottle of Penguin Sportwash, either from Taiga or Choices market. Restores performance, completely removes odours, so says label.HE. I have used it only on one jacket so far.Both seem to be good.
Exploding Washers
Are almost always TL machines, FL washers tumble the water out of folds and pockets etc better so they are much likley to have a load spinning at 800 RPMs+ when the pocket of trapped water lets loose and the washer is violently ripped to pieces.
It does little good to monitor the washer while running [ in fact it might be dangerous to be near it ] And the unbalance systems CANNOT prevent this problem with loads that suddenly go out-of-balance, because the load was perfectly balanced until the trapped water is suddenly released, it is the same as dropping a brick into a washer spinning at full speed, NO washer ever built that spins at speeds of over 800 RPMs can survive this problem.
John
