mamapinky,
I don't know the ingredients of OxiClean. I can't find ingredients list. Similar cheap European products contain sodium carbonate, sodium percarbonate, silicate and non-ionic surfactant. Such products have some positive effects in stain removal mainly because they increase the pH of the solution and add some more surfactant. However, products with activator blow away that cheap stuff. They are more expensive (because the activators are expensive), but work much better.
I don't know why it has been recommended. The question is why do you use it? What does it make for you? You see, when you use sodium percarbonate without activator, you have ineffective bleaching only when the temperature of the solution is above 55-60°C. Yes, it is not completely useless as it has some bleaching and disinfecting properties in high temperatures and high pH. Product with activator on the other hand gives you very strong bleaching from the moment it dissolves and the chemical reactions between the components begin.
OK, you can use percarbonate and it will probably remove some light bleachable stains but if you want to keep your whites white for a long time you need effective bleaching system.
