Solid tub automatic washers
adam-aussie-vac
Dec 14, 2017
1,026
Canberra ACT
Does anyone know if a company has made a solid tub washer in the last 50 years? The closest thing I have to a solid tub washer is my seimens spin dryer which only has slots in the bottom of the drum but still does a good job at 3709 rpm, also on a partially related note, when did spin dryer drums start to have holes in drum wall?
Servis
Hi Adam
We had the Servis quartz here with its spincare drum. It had slots at the front and back and was slightly bevelled to the middle. Here are two different models with the same drum. It was designed to be more gentle on clothes.
S
Interesting
Advertised as "new" it is a very old concept. Nearly all the top load machines from the 50's were solid tub design. It also brings up an interesting point about bacteria and gunk that perforated tub machines to seem to accumulate. Years ago in some areas of the country perforated tub machines were considered unsanitary in laundromats due to the remaining water in the pumps and outer tub at the end of the cycle. That was back when Speed Queen ruled for laundromats.
Again many modern H-Axis and top loading washing machines
Even with two tubs (suds container and outer drum) use far less water than in past. Thus any savings with a solid tub washer would be negated by other issues such as loss of pressure fill, having to clean inner tub/suds container, and so forth.
Comparing holes in suds container of my older Miele W1070 and Oko-Lavamat you can see the latter already has much smaller. The new "diamond" or whatever inner drum craze started by Miele (and now widely copied) has reduced hole diameter still more.
Miele's stated goals for their new tub was fabric care (much like the Servis noted above), but those tiny holes also mean less water goes between the tubs.
That sand test is about as obsolete as the girdles worn by Ms. Betty Furness and the other ladies.
Few if any households today generate that type of laundry today. Maybe lifeguards on a beach have things with sand, but who else?
Young children (prime generator of dirty clothing back in the day) spend more time indoors or whatever (such as playing video games or other tech things), than running around in dirt/mud. Haven't seen a sandbox at a playground in years. Though maybe they are still out there elsewhere.
Majority of laundry today ranks between lightly soiled (with body dirt mostly) to perhaps food and drink stains. It is one of reasons why powdered detergents are being so easily given the push by liquids. Much less laundry is generated covered in "clay" based soils. Sweat, oils, and similar, that they've got.
Sandboxes went away because cats used them as litter boxes-would you want your kid playing in that?For homes-household litter boxes had a cover for them when not being used by kids.The cover kept the cats out.Haven't seen sandboxes since I was a little kid!
Sand And Grit Is Still Just As Much In Laundry As It Was
In the 50s and on through the present, fortunately it is not a great problem because washers today deal with it very well unlike most solid tub washers did, in fact lint,  re despoted scum and sand and grit problems were what did in solid tub automatic washers.
Even the better early AWs dealt with sand, grit and scum very well, of course the best selling maker WP & KM never had any problem along with Bendix FL washers, Westinghouse, Blackstone and even the ST GE FF  washers were pretty decent on getting rid of sand and grit, so it was only a number of ST washers that really had problems and we all know what happened to all of them.
John L.
