Solid tubs
tcox6912
Sep 6, 2004
122
Who was the last company to use a sold tub on their machines? Who was the first to start using plastic outer tubs on their machines? I know that some used a porcelin inner tub, but plastic outer tub. Inquiring minds want to know? Todd
Consumer Reports always rated solid tub machines poor in sand disposal. IIRC, the Whirlpool/KM direct drives machines were the first with plastic outer tubs. GE and WCI Frigidaire seemed to be the first with plastic inner tubs. Just my impressions, I could be wrong.
The last solid tub!
The very last solid tub machine was the 24 inch frigidaire adjitub. Was completly plastic. Inner and outer tub. Was made until the end when wci pulled from gm.
Peter
WCI wins!
The plastic outer tub pre-dates the Whirlpool direct-drive machines by years - WCI was using it on their compact washers in the mid 70's and then that same mechanism design was incorporated into the Skinny-Mini cabinet and available on the market by 8/79 once the takeover of Frigidaire by WCI was completed earlier that year.
I have one.
I have an older SQ in storage. It needs a little work to bring it up to par. If anyone is interested in taking it on, let me know.
Steve K and I put a new motor on one similar to this earlier this year here in Atlanta. It's also a non-solenoid machine but does have the stainless steel solid tub and overflow rinses.
Hey Eddie,
What year is that beautiful SQ of yours? I thought they continued to manufacture solid-tub machines on into the 1980's.
I have two and one of them is a "large-tub" solid-tub machine with reversing motor that I thought was manufactured in the early to mid-1980's.
That combination of white porcelain tub and white agitator is very elegant. My late-60's (Three-Speed) SQ has the Gray and speckled porcelain tub and gray agitator.
The new Speed Queens have am excellent warranty...and it is...drum roll please....
3 years parts and labor
5 years limited warranty on cabinet assembly against rust inside and out. Year 4 thru 5 parts only limited warranty.
5 year year limited warranty on the motor.
10 years limited warranty on transmission assembly.
Lifetime warranty stainless steel washbasket and outer tub.
Not bad I say and better than a 1 year only warranty most others have.
