michaelman2
I think when asked what is my favorite entree it would have to be really well prepared southern fried chicken. Not greasy or heavy, but flavorful, tender, crisp and pan fried NOT deep fried.
I have a recipe that is really a culmination of several recipes and regions, it is truly the best I have ever have eaten. To me fried chicken is to me an "art" or a labor of love. I know that reads as hokey...
When I find a restaurant that can really "throw down" on fried chicken, I find their other items are usually the bomb as well.
When I lived in NY and Chicago this was a Sunday dinner staple. In my experiences during the 1980s, southern foods were still for the most part in the south. When I would cook a Sunday dinner for friends whom were reared in the north, they had never had authentic fried chicken, southern green beans and biscuits. (or they had not had the southern versions of the aforementioned).
Sweetened iced tea was affectionately called "table wine of the south". These guys would eat like they have never eaten before. The fried chicken was something they loved and I loved making it for them...
INGREDIENTS
1/2 cup coarse/kosher salt
1 chicken (3 pounds), cut into 8 pieces
1 quart buttermilk
2 pounds lard (not the Hormel hydrogenated, boxed lard or Crisco) Peanut Oil will suffice if lard is not available. *lard is not as bad for you as you may have been lead to believe and if you can find it at a local butcher or grocer, it is very worth the find.
1 cup (2 sticks) unsalted butter
1/2 cup country-ham pieces, or 1 thick slice country ham cut into 1/2-inch strips (thick slab bacon will suffice in a pinch)
1 cup all-purpose flour (White Lilly if available)
2 tablespoons cornstarch
1/2 teaspoon freshly ground black pepper
1 teaspoon seasoned salt
Optional for Buttermilk brine: 4 tablespoons Texas Pete or Tobasco
DIRECTIONS
1. In a large bowl, mix together 1 gallon of water and 1 cup salt; stir until salt is dissolved. Add chicken pieces and let stand, refrigerated, 8 to 12 hours.
2. Drain chicken and rinse out bowl. Return chicken to bowl and pour buttermilk over chicken (if you are adding the Texas Pete/Tobasco mix it with the buttermilk and then pour over chicken). Cover bowl and refrigerate 8 to 12 hours. Drain chicken on a wire rack set over a parchment paper-lined baking sheet, discarding buttermilk. Also gently squeeze off the excess buttermilk, you want the piece to be as "dry as possible.
3. Meanwhile, place the lard, butter, and country ham into a large heavy skillet. Cook over low heat, skimming as needed, until butter has stopped foaming and country ham is browned, 30 to 45 minutes. Using a slotted spoon, remove ham and discard. Increase heat to medium-high and heat fat until it reaches 335 degrees on a deep-fry thermometer.
4. In a shallow bowl, mix together flour, cornstarch, seasoning salt, and pepper. Dredge chicken pieces thoroughly in the flour mixture, shaking off any excess and also "pat" the piece to ensure you do not have excess flour. (you can place the dry ingredients in a large Ziplock and shake them in the dredge if you prefer)
5. Working in batches, gently place chicken pieces in the heated fat. Cook until chicken is golden brown and cooked through, 8 to 10 minutes. Transfer to a wire rack set over a parchment paper-lined baking sheet NOT crumpled paper towels. Serve fried chicken hot, warm, room temperature, or cold.
The corn starch will create the very deep golden brown color you see on the chicken I prepared. It is not burned or overdone, it is almost caramelized. I promise you on this recipe, perfect it, and you will be the fried chicken king or queen, it's that good!
INGREDIENTS
1 quart buttermilk
DIRECTIONS
