As some of us may know, Bosch has issued a recall for many dishwashers made in the past five or ten years. Mine fell into the recall, which was voluntary on Bosch's part. I called the 800 number and was told they'd send me the part, but that Sears would have to do the install.
Fine, I thought. I could do it myself but would rather have it done officially just in case something goes wrong with the new part.
Sears repair (A&E) arrives well on time (in the middle of the four hour estimate). Fellow is clean and polite. I work in the other room on some classwork. I hear a lot of fumbling in the kitchen. He's having problems freeing the connectors from the old controller.
I ask: "Have you done this before?". He says yes, and I leave him alone.
20 minutes later, he's fumbling trying to stick the new controller back into the metal frame. He asks me to hold the door for him, which I do.
10 minutes later he's got it all buttoned up, and starts to read the instructions on how to program the codes into the controller. It doesn't seem to work, so I give him a hand. We kind of sort of get it to work, except now the Quick Wash is taking 58 minutes instead of 30 minutes. He says it's the way the new controller is supposed to work.
I sign the receipt and he's on his way. He leaves the old controller and all the instructions. I note immediately that in order to program the control codes, it needs to be done BEFORE putting the control panel back together, because a fifth button is hidden from view after it's put together, and that button must be pressed along with three others to program the codes. So I get out my Torx set and re-open the control panel. In about 10 minutes I figure it out (the LED display shows the code instead of a pattern of lights above the buttons). Get the right code set and the machine now displays about 30 minutes for the Quick wash, just like it's supposed to.
I button it up and run a full cycle. No problems. I wonder if the 58 minute mistake was for a gentle cycle (different model). Oh, well, I like having the Quick cycle better. Beside, after pushing the right buttons, I couldn't get the 58 minute time back, instead it showed up as 85 minutes. Quicker than the 105 for the normal cycle, but definitely not quick enough.
Yes I did cuss out the repairman after he left, but then I figured I got to do it myself after all. While maintaining whatever warranty might accompany the recall repair.
And so it goes.
I wonder how many other dishwashers this guy is going to foul up before he reads the instructions, lol...
And so it goes.
