1970 Australian Womens Weekly Pavlova Recipie
Hi Guys,
Please find the recipie below. I have included the recipie for a single batch, but I usually double it.
3 Egg whites
pinch salt
3/4 (Metric) Cup castor sugar (190mL)
1/4 (Metric) Cup regular white sugar (65mL)
1 (Metric) Tablespoon of Cornflour (20mL)
1 (Metric) Teaspoon of Lemon Juice (5mL)
Preheat oven to around 140degC. I use this temp with the fan on, you'll need to experiment with the temp in your oven.
Take a Biscuit tray about 12" square and cover with greaseproof paper. Lightly spray paper with cooking spray and then dust with cornflour.
Mix together regular white sugar and corn flour in a seperate bowl and stand aside.
Beat egg-whites and salt until soft peaks form; add castor sugar gradually, beating well between each addition. Make sure the sugar is completely dissolved. (can take up to 10-15 minutes depending on your mixer). Mixture should be very stiff and shiney.
Fold the granulated sugar/cornflour mixture and lemon juice into the meringue. (Do not over stir)
Scrape the mixture onto the prepared tray in the middle, and shape into a circle about 2" high.
Bake until a pale fawn colour and the shell has become hard, once this stage has been reached, turn the oven off, leave the door ajar and leave the pav in the oven until cold. If you find in the first 15-20 minutes that the pav has coloured, turn the oven down as the colour shouldnt change until after the shell starts to firm up. Lower temps are better than high ones. My usual cooking time for a pav of double this size in an electric Fan forced oven is around 1hour - 1:30, you will need to monitor however as every oven is different. I cant stress enough with this, dont rely on time, check every 20 minutes or so.
I whip together pouring cream, vanilla to taste. I dont put any sugar in the cream, as I figure the shell is sweet enough. Then decorate with seasonal fruit, traditionally Kiwi, Strawberries and Passionfruit would be the way to go.
