Speakman Anystream Carries the day
jetcone
May 2, 2001
7,678
Schenectady-Home of Calrods,Monitor Tops,Toroid Tr
So AW'ers its Speakman season! I've been playing with vintage Speakman shower heads lately. When I first became aware of the brand in a hotel in the late 1970's I thought someday I'm gonna get one of those for my shower.
I scored a late 1960's Speakman off a friend who was selling his house and was about to toss it out as it didn't conform to the new "dry shower" standards doled out by the "water nazi's".
Installed I took my first 'Full Blast©' shower in decades! I must have been using 7 gal/min.
So I was HOOKED! On the hunt I was.
Then I found it-- a good used condition 1928 model 1 Speakman -- ALL BRASS shower head. It weighs in at 3 pounds of solid cast brass!  "Electrically melted to insure fine grains of brass..." So states Doctrine !
When I installed this baby last week, it practically blew me to the back of the tub!! It would certainly blow our Webmaster to the back of the tub and nail him there!!!
[this post was last edited: 7/21/2015-07:24]
It even reveals
the "Forbidden Flow Rates©" !!
Now if I can just get the city to call me back on my water pressure I can know just how much is blasting by me in the shower !!
I must say after a solid week of 1928' Shower-Baths that my shower time has been cut in half! So I am now wondering just how much water I am saving or not. Higher pressure = shorter shower time /// Lower pressure = longer shower time. But whats the true water savings? We'll know once I get the figure from the City!
Robert had some Forbidden Doctrine he was hiding , but  I forced him to publish it in automatice yesterday !!
"Washers are made of long-wearing composition of rubber and asbestos fibre."
Yikes!
How about an action shot of the thing pumping water? ;-)
Thanks a lot, now you've inspired me to find myself a vintage Speakman! ;)
I've always been a fan of them and have a few of the modern ones, one all brass and two plastic. I have picked up quite the collection of shower heads over the years in the quest for the perfect shower and for the last two years have settled on an Italian made Siroflex shower head.
"It would certainly blow our Webmaster to the back of the tub and nail him there!!!"
Although there would be less surface area so, perhaps, correspondingly less force. Smaller is not necessarily better or worse, just different.
I really like my handheld shower and with my quarter turn faucets, it is very easy to turn off the water once I am wet and the washcloth is wet and not use any water while I scrub then turn it on for rinsing. I don't need the highest water pressure because I can hold the water source near any area that I am rinsing. By using only my FL machines, mostly using the Miele W1986 instead of the more water-hungry W1918 and only using water outside my house through the special meter that does not charge me for sewer on water for the yard, I have reduced my daily water consumption to the recommended amount by the Washington Suburban Sanitary Commission. I am anxious to see how much more of a reduction I can make by turning off the water while I scrub myself, even though I used to turn the setting on the handheld shower to the maxi-save position while washing.
I also have a valve that allows me to use the regular shower head. I read that often when you have a headache or a stiff neck, the tension arises in the calf muscles so when that happens, I can stand with the water running on my back and lower legs to loosen the muscles. When I can bend over and touch my feet, the muscles have been relaxed and the tension in my neck or scalp is gone, too.
Phil
love that box photo! LOL how the man needs the "stimulation" setting !!
Tom I first used a telephone shower aboard the Queen E2. I must say it was direct and stimulating! Have to save water on board so all the showers were telephone showers as the English called them.
I put a link up on Square, there's a guy selling some with a removable flo restrictor from a Vegas hotel. Nice head not expensive too.
[this post was last edited: 7/21/2015-13:48]
The Needle Spray...
...will nail you to the tub!
This box reminded me this Eaton Vibra Queen home massager that I have!
Use the scalp applicator and feel the tingling sensation... I just tried it for a few seconds and now I have a headache!
I guess, the tingling sensation might be worse if you use it in a damp location like the shower or the bath!
That thing must be old as there's no notice against doing such a thing.
I think with higher water pressure you use less water. We have high water pressure here in our showers. I can hop right in and out very quickly. Maybe 10 min for everything. We once had a house with low water pressure. It took 30 min to shower and rinse off properly.
The showers here will definitely blow you against the back wall if you are not ready for it! Plus we use a Delta hand held shower head with an inline chlorine filter too and the pressure is still strong.
Have a Speakman or two around the house and really like them but I'm more than happy with the shower system I put in a few years back.  4 body sprays, a large fixed pulsating shower-head, and a rarely used hand held shower.  I use the body sprays and the fixed shower head daily - all at the same time, only time I use the hand held is when I scrub down the shower.  I'm about a 10 minute user too, odds are about 6 minutes of full flow water use.  It's a Delta system and when I installed it I was tempted to drill out the 6 position diverter valve,  it has 1/2 feeds coming it, but only a pencil sized opening in the valve.  I didn't but sometimes I wish I had when the water pressure is on the low side due to whatever.  Does not happen often though.
Other bathrooms get Speakman brass units, never plastic.
Will you guys just stop dancing around it and write what you really mean? Sheesh.
Well, I just went into my drawer of shower heads and pulled out my S2252 and put it in. Nice to have a solid hunk of brass hanging from my shower wall again...
I have a Speakman Anystream, bought it after using one at friend's or hotel (?)
Mine is like the ebay model with the plastic and o-ring restrictor. I pulled the o-ring and broke away the plastic ring, so it's a full-flow model now. I've tried others, including a cool vintage Water Pik massaging head and always go back to the Speakman. We have 70+ pounds of pressure in the house most times and you almost cannot stand to open the valve completely, it's too strong.
Some of the ebay prices are astounding. Wow.
The Speakman all metal showerhead I bought didn't have the plastic or rubber flow restrictor ring you could remove-I had to drill out the restrictor on the shop drill press-Much better-I like "firehose" showers!I HATE watering can sprinkle showerheads!
I was afraid mine would have to be drilled, too, but it was just the plastic and that o-ring. I think only the outside case of my Speakman is metal, the rest is plastic. I have the pull-on Moen shower valve so can control the pressure completely. The new Moen tub/shower valve we put in the main bathroom when we remodeled is a turn-to-temp valve so it's probably limited flow as well. The Moen shower head that came with it is a restricted flow but it's not terrible. Not a firehose (lol) but adequate.
Vintage speakman help
Hi, I was so happy to see your post. I was hoping you could look up some info in your book about the mixometer. Mine is too cold and we have to run the tub cold water pretty hard to get hot water from the shower. I was hoping to get some info on what’s inside the mixer to see of it can be reworked, The shower wall is solid marble and backs into a bedroom. Only one pipe shows, the other must be behind the walls.
Cathy,
After many decades,  the hot side of the mixometer is likely suffering from serious mineral deposits.   The valve probably just needs a good cleaning.
There's a 1950s catalog for downloading on the Ephemera site which might contain similar information to the 1939 catalog pictured above.  Here's the link:
https://www.automatice.org/cgi-bin/index.cgi?showdoc~1279~Speakman~
