Speed Queen Centerposts 101
I simply cut two strips of this plastic and used 100% silicone to seal them over the holes. I completely covered the plastic patches and all around them to hold them in place and provide a permanent water seal over the holes. This part has no structural purpose other than to (normally) hold the water until it can be pumped away. The silicone and new boot will do that nicely and other than some sticky-gloved fingers, the whole job was over in 15 minutes. I also used the same silicone to cover and seal up any other rusty bits in the tub and inside the flange for the hose to the pump.
Looking good Greg! You will have that one finished in no time. Will we get to see the action shots?
Oh Greg that silicone job looks Great! I bet it would last another 40 years like that. Great restoration Photos as well, once this thread goes into the archive we should put a link to it on the restorations page. I should do that with a few other ones as well.
Sediment Ej...
I didn't replace the sediment tube - the old one was clogged beyond hope (as most are) and I usually don't fool with them. I used silicone to seal the ejector hole in the bottom of the centerpost but I didn't put silicone in the channel at the bottom of the tub - yet. I'd like to see how much water remains in that after the spin and then may decide to do that. As you can see by the pictures, I've used quite a bit of silicone already - I mused last night that I mosiquito or housefly will never even fly over that machine with all the gasses that are leaching out of the silicone ;-)
Last night, after the silicone & ice cream bucket patch had a chance to set up, I installed the new tub boot. This morning after everything was completly dry and solid, I replaced the spin-hub gasket and re-installed the tub and the four bolts holding it to the hub, the agitator shaft, thrust collar and finally the agitator & cap. We're ready to wash again!
The washer is now finishing it's fifth load for the day, all is well - quiet as a Speed Queen can be and so far, water-tight!
Thanks for all your great comments and support during this rebuild job. After a few loads in the dryer, I need to hunt for a few minor parts to make it "whole" again as well. Door latch catches and possibly new drum rollers will make it run like new.
It never ends, there is always something more to work on!
Hope everyone had a great weekend!
Great pictures Greg and another wonderful restoration!! I just love the rinse water shot, such fun! Thanks for sharing the entire process with us.
Fabolicious!
I love the plastic bucket method. That's awesome!
Congratulations on getting the GuacaQueen up and running, and thanks for the excellent shots and step-by-steps! :-D
Great job Greg! Glad to see the action shots so soon also. I have never seen a Speed Queen in live action, but they look like a fun machine!
thanks for showing your work. It is rather similar to older model GEs. Even the outer tub looks similar. I have never seen a Speed Queen dismantled.
Thank-you. great pictures.
