I have a Speed Queen Dryer that is five years old. Model# ADE4BRGS171TW01. I dry 4 to 5 loads per week, and it has been well cared for. Two weeks ago it just stopped drying (heating) on all cycles. I called a friend that is an Electrician and loves to troubleshoot any electrical problem. We have gone through this dryer inside and out, along with assistance from Speed Queens Tech Support. I keep the vents and dryer pipe clean and all times. I have no lint build-up at all. Every part has been checked via ohms, voltage, ect...with the Electricians meters and other equipment while S.Q. tech support was on the phone verifying the correct readings. Everything checks out perfect. Even the power coming into the house, breaker box, wiring, dryer plug, all check out. S.Q. Tech Support had me to replace the Timer, Fabric Selector switch, and the Thermal fuse. No change. I went ahead and replaced every part in that dryer. The power cord, Heating Element, Limit Thermostat, & Cycling thermostat. Now I have very low heat on the Regular Fabric Selector switch setting...and with the Timer set to "Timed Dry". All other settings I get cold air only. S.Q. had me to switch out again the Timer, and Thermal fuse. I exchanged them at the appliance parts store but no change. It doesn't make any sense. Everything is brand new using genuine OEM parts. The only thing that has not been replaced is the wiring harness. Is there something we have overlooked? Any help, advise or suggestions would greatly be appreciated.
Charlye37
Charlye37
