I LOVE my SQ FL washer. Made big mistake & washed Vellux blanket which disintegrated into million tiny tiny pieces. Checked foreign object trap under machine & no bits found there.
What now? Could some foam bits have gotten thru drum holes into hose/pump? would running several empty cycles 'clear" the bits (per SQ CS, although she had no clue where pump is).
Excuse my naive question. Does dirty water go from drum to hose & into pump?
I dont want to damage pump.
thank you.
thank you.
