Speed Queen if listening- Brastemp got it right
Not so much a fear of semi-conductors,
but a fear of cheaply made electronic controls. I think that it is quite apparent, with the number of board failures on modern machines vs the number of timer failures on slightly older machines, that while QUALITY electronics are more reliable than mechanical timers, the electronics made at a competitive price point to a quality timer are simply not. A fair quality mechanical timer is likely priced at around what the cheapest electronics cost, henceforth why timers lasted so long and why the replacement electronics on modern machines fail so soon. Even the electronics on TOL '80s and '90s machines were of better quality because they were not built to a price point.
Might I add to this with a reminder the average SQ customer did not want electronics at all cost. Also, electronics add no more features than timers could on TL machines, in fact I think that they are less flexible. You are stuck with the cycle programming and the options they gray out. Also, since when does everyone need 25 cycles of which there are only likely 4 real cycles backing them up with only minor changes changes to what the cycle lets you select. For example, I ask what is the difference on a TL washer with a separate full fill option between "Bulky" and "Heavy-Duty"?
@Johnb: Thanks and no hard feelings :) Yup- its been around for a very long time- simple and elegant. And you aren't behind- I am learning a lot as well.
@kb0nes:
"But then you lose all the ability to ramp and brake the motor in a controlled fashion. I just don't seem to see the advantage of needlessly making a machine crude."
You don't need that level of precision control in a VMW. A simple rotating drum and a rapid advance timer is enough do mimic an electronic triac or thyristor control. For agitation you simply cycle power to each motor lead for 1/4 of a second with 1/5 of a second pauses in between. Far simpler then an electronic inverter polluted with computer chips generating 3 sine waves 120 degrees apart.
As for braking that has nothing to do with the motor. The timer drops power to the spin direction lead, and then a few seconds latter the pump shuts off which also causes the solenoid to let go applying the brake band to the drum. Even if electronics were present in the machine, they still would not be responsible for breaking.
"I find it an interesting paradox using the Internet to share views of the fear of semiconductors..."
Semiconductors have their place- but in a clothes washer I'd rather pass. My computer doesn't throw error codes, and when (if) it does there are automatic software updates to fix those bugs.
Jon, Jetcone
"I thought that motor was electronically controlled,, its not?? That motor reverses on its own somehow??"
I was referring to the machine that was mentioned in reply #23 that didn't have the scourge of any semiconductors in it apparently. Not sure what that machine was but it seemed a silly way to design something today. Sounds like there is some contactor that just flips states and reverses the motor or something. Hope they picked a good one or those contacts will fail before any transistor would.
This would be a good choice for those that really fear electronics, alas some convenience might be lost. lol
Thats one way, or being less silly, a separate rotating disk or drum in the timer which rapidly cycles the two leads. Most washers did it that way before semiconductors came along. It worked well with no issue.
