Speed Queen Service Call
mrb627
Sep 12, 2001
5,119
Buford, GA
My Speed Queen dryer has begun making a grinding hum that has gradually gotten louder over the past month or so. So, I placed a service call with my local service master. Beforehand, I tore the dryer down to the baseplate and ran it in air fluff mode and diagnosed that there was a bad bearing in the motor.
Placed service call Friday afternoon. Technician was here on Monday. He agreed with my diagnosis and placed an order for a replacement motor. Should be received in a couple of days.
Will keep you posted on the outcome.
Malcolm
Thats pretty good and quick service I would say. Since you did the hard part for him in finding out what was wrong. When I bought my Maytags in 1984, the only dealer in this area was fine to sell you something at a tidy profit, but when it came for service, forget it. They ended up going out of business and several other appliance dealers took the franchises on. The old fool is still selling appliances at Home Depot last time I knew. I wonder how he likes Maytag now?
Posted...
I'll keep you posted of the progress.
Malcolm
( I should have taken pictures during teardown )
Wow.. That's kind of odd that the motor in your dryer failed so soon. you've only had that set for what.. about a year or so?
2.5 years (almost)
The service tech that was here said that it is rare, but he has seen more than a handful of motors with bad bearings. Trust me. You'll know if it starts happening. And it should happen within your warranty period.
Malcolm
Is Speed Queen outsourcing their motors? I'm guessing they are because there is very little motor manufacturing going on in this country now.
Bad SQ Dryer motor
SQ uses Emerson motors assembled in Mexico like WP and some Frigidaire products. They are generally very good motors, but there are always some failures of anything and a motor can fail at any age and the older it is and the more use it has received the more likely it is to fail. The only usage factor that we see over and over again when it comes to dryer motor failures is dryers that have a poor vent system diffidently have a much higher motor failure rate. This seems to be because the motor runs hotter and the dryer and motor also accumulate more lint buildup inside and around the motor.
The good thing about SQ is the motor is covered parts and labor for 3 years and you get a no charge motor for five years, with WP, MT, KM, GE, Frigidaire you get just one year period, so you end up with a two to three hundred dollar repair bill.
Diagnosis
I gave him my diagnosis before he looked at it.
Malcolm
True, the motor alone can run just under $200.
skeptic
Hi Gary, the dryer is under full warranty for parts and labor, so it probably doesn't matter. I do agree however that unless the technician is having problems figuring out what the problem is it is often better to let them figure out what is wrong before you offer your diagnoses and then discuss the possible  solutions.
True
But my main concern was being told that the noise was normal. Some techs like to do that if they think you are clueless.
Malcolm
I hate that Malcolm! In my business I manage a team of engineers that design motor drive systems for a living. So when I am face to face with a tech that is telling me something that is as pure bs as the sky is blue (and trying to do it with authority), I have to restrain myself from kicking their a**es right out my front door.
Glad to hear that you got your motor replaced quickly.
I'm sure other people with your problem would have just kept using it until either the motor was squealing or locked up from bearing failure.
Not Yet
It hasn't been replaced yet. He ordered it Tuesday morning. I told him next week for the replacement would be fine.
Malcolm
AWN412 Tub
I bought this Speed Queen washer in February and we really do love it. It washes and rinses great. However, I watched a You Tube video of a similar washer and noticed the tub actually agitates during the wash. So I used a clothespin to override the lid switch to see if mine does and it doesn't. The tub moves a little back and forth during agitation, but it doesn't move all the way around. Should I be concerned? Should it move? I thought about contacting SQ to ask, but I figured they would say something about me overriding the switch to watch it agitate..
Thanks,
Tim
Tim
If you can reference a link to the youtube video that you are referring to, we might be able to explain the behavior of the machine in the clip.
Malcolm
With my SQ washer the wash basket did index when we first got it. Now the wash basket doesn't index unless the load is heavy like jeans or towels then it might index some. Timborow have you raised the water level on your machine? I had to raise mine since it was way too low for my loads. I like the wash to move freely.
Thanks
I guess I am worrying for no reason. The machine works great. I just wondered if it should work like those in the videos. Maybe the machine in the video was just made differently since it was 2009 machine.
Tim
Motor In
Got a voice mail from the service company this afternoon. My dryer motor is in stock. Should be installed early next week.
Malcolm
The topload will stop indexing...eventually depending on use - the one at the condo (used rarely) took nearly a year! :)
