Speed Queen Spins Getting Weired
Chetlaham
Mar 11, 2013
5,501
United States
At first I was upset/surprised by the default low speed first spins in each cycle. Now it seems like Speed Queen 15 seconds into the first spin pauses, starts the motor for 1/2 a second, pauses for 5 more seconds than goes back to low speed.
Huh? Why? Is this intended? I'm confused.
Starting at 18:28 and 1:00:30 >>>
[this post was last edited: 7/17/2023-08:39]
Could be, though I'm leaning toward it being intended since it does it in both cycles exactly after 10-15 seconds of spinning. At the same time, I can't thinking of any gain of stopping and cycling the motor mid spin drain other than some type of overload like binding in the pump.
Reply #5 good catch Marco.
Along with what Marco said, it seems to drain pretty slowly compared to my machine which seems almost instantaneous when the spin starts.
Maybe if it's not draining as it should it causes the water to slosh over as the machine spins up higher triggering the overflow?
I'd probably check the pump.
Ok, yes, I see that now! Wow! I never knew these even sensed an overflow condition.
What would cause this? Could the flood pressure switch simple be set to low? Or is the machine actually spinning to fast?
I'd think, IMO, that even with a slow drain pump the tub should still drag indefinitely at a speed that doesn't cause water to overflow out of the top.
Still appears to me that it is draining very slow, and while the belt is designed to slip, it could still be gaining too much speed before the water has time to go down enough.
So I would still check the pump to make sure it's not partially blocked or just going bad.
Also, speaking of the belt, check that it is indeed the correct belt and not a replacement from an auto parts store or something that's not designed to slip. I understand that may be possible?
In any case the slow drain does concern me. Maybe compare to other videos and see if you agree or if it's just me.
the machine is flashing that oFlo msg in the first and second spins the third time the machine drains the msg once again pops up but the machine doesn't stop like it does on the first two
My Speed Queen TC5 also has a slow spin after the wash, it still drains much faster than the one here in the video.
I wouldn't think my machine is special, but I've wondered at the thread that asks why Speed Queen spray rinses when the tub is still full of water. I've watched mine, and the water as far as I can see is in fact drained by the time the spray rinse starts, even with a tub full of water, and that's 30 seconds after the spin starts. Yet around 20 seconds after the spin starts in the video, the water in the tub has barely gone down.
Maybe the faster spin makes the water go down faster than the centrifugal forces the water over the top so it doesn't fault out as much. I don't know, but I still don't believe it is draining right.
Drain During Slow Speed
I would say my Speed Queen drains a bit slower than this machine when on low speed, if not equal. And yes, my AWN412SP sprays with the tub still 1/3 full of water on Permanent Press and Delicate with the water level on medium or large.
However, what I notice is the tub spins and accelerates faster during spin-drain where as my machine spins slower during drain, also water doesn't slosh up and down the tub cover like in the video.
I'm now waging a bet the belt isn't slipping enough.
But I sure do like seeing that enhanced swirl-away drain
The motor should not cut out on a low speed spin-drain. The slip in the belt is supposed to prevent the motor from being overloaded with to much torque. It is physically impossible to spin a tub full of water at 640rpm with a practically sized motor so some type of clutch must be used, be it a shoe/drum or a variably tensioned belt.
However, thats not to say I disagree with you Jerome. I'd absolutely loose my marbles if my Queen spun low speed in the normal cycle.
I think Speed Queen needs to listen to those posting on this forum.
My guess is that either the wrong belt is on the machine or it's too tight (if there's an adjustment), causing excessive current draw on the motor in a way that's specific to low-speed spin acceleration, if that's a possibility.  The belt on this haul-away machine was bad and replaced before running it, per the video's description.
