blockeight88
Good day,
I have a 2 year old Speed Queen TC5000WN washer. I will try and get straight to the point. I like to switch between this and a Kenmore 80 Direct Drive. I am not sure by doing so if I have messed up the springs in the TC5. I have thoroughly researched the tub leaning and from my research, have gathered this is "normal operation". My issue seems to be more prevalent than others. My flooring was recently re done and since I have reinstalled the TC5, I cannot get the tub to excessively stop leaning.
The machine appears to be level front and back, side to side (maybe off very slightly, but still within the level lines). After about a dozen times re-leveling the machine, I feel I may have made matters worse. The tub is now leaning to the right rear (opposite direction of the motor torque). I have tried to add some foam to the front right spring to secure it in place, but that doesn't appear to be working.
I understand that all SQ washers will lean to some degree, but how do I get mine to lean at least forward with a little pull on the side?
I have read on these forums the best solution is to add some foam to secure the springs to help with the torque. Perhaps someone can share a photo of how they have tweaked the interior with foam because I’m stumped and don’t want to make matters worse?
Here is a link to my video demonstrating the issue.
Any insight is greatly appreciated.
