Speed Queen Wash Cycle Temp when using Prewash AWNE92SP
dylanmitchell
Jan 7, 2018
124
Southern California
For a 2017 SQ AWNE92SP113TW01 what temp is the wash cycle when using pre-wash? For example, if you set temp to warm and select prewash is the wash cycle warm or cold? Wondering if both washes are the selected temp or if the second wash is cold vs the selected temp.
I've tested the water in pre-wash and it matches the temp set for the wash cycle. I'll have to test the wash cycle water temp next time I do a pre-wash load. Rarely use pre-wash but it's a question I had and the manual didn't answer. One of this washers nice features is it doesn't drain when you turn it off so you can fill it with any temp water turn it off then on and select any setting like pre-wash to use different temp water.
