dustin92
We recently moved into a new house which we are in the process of buying from family, and even more recently; we started work in the lower level / walk out basement. There is a late 80's or early 90's Speed Queen washer and dryer that have been there since new. I did not know the working condition of the machines until today. I would like to repair them, because the seem to be very heavy and well made. I ran two loads and the biggest issue I saw was with the washer, the the timer knob (the part of the knob that is pushed in, set to the desired cycle and pulled out to start) is stripped/ broken somehow. I had to turn the actual dial (with the orange pointer) to select the cycle, and then pulled out the knob. The washer filled fine, and stopped at the selected water level, then seemed to agitate normally, but made one heck of a racket. Nothing at all like the last Speed Queen we had, wiich emitted a low hum. It sounded kind of clunky/ rough/ rattly, but none of the sounds were carried through the agitator (felt smooth when I rested my hand on top). Toward the end of the wash, and into the rinse, it started squeaking at a rather slow but steady pace (maybe the belt?) It made the same sound, at the same speed when it went into the spin cycle. It sounded fine while spinning (no noise from bearings). It spun both loads out well and they were put into the gas dryer. DRYER: The dryer (natural gas) seemed to dry very well, I actually completely overdried both loads. I dried a load of lightweight curtains and a few pillowcases for about 45 minutes and they came out hot, staticy and crisp after about 30 minutes. The next load was a load of whites, mostly heavy towels, which I set for 65 minutes with the same result after 55 minutes. It definitely dries fast. The only issue I found with the dryer, it thumps as the drum rotates, causing the cabinet to rattle.
