wildmanwill
Hello!
I'm new here, after much research including reading here on this forum, I was fortunate enough to be able to purchase an open box Speed Queen AWNE82SP Top Load Washer in late February.
We are having an issue though and I was wondering if someone here may be able to help us troubleshoot it or may have had a similar experience. It would seem that we intermittently end up with water under the washer.
The drain and fill hoses are all tight are not leaking on both ends.
We are using the proper amount of detergent for the load
The tub is still centered properly after loading
This happened twice with full loads of towels, and once with a medium load of dish towels. The first time was about 4 weeks ago, and the other two occurrences were about a week ago.
I pulled the front cover off the one time and could not see anywhere obvious where water had leaked from.
The last full load of towels I stood with the machine the entire time and we didn't have any issues. I guess a watched washer never leaks?
I did notice that the machine still indexes when towels are in there (heavier load?) but I hadn't noticed the indexing on some other loads that we recently did. A few other observations during this load (with no leaks), was that when the washer was spinning and water was being added that some of the stream hits the edge (see photo below). I also observed some bubbling later on when it was not spinning but filling (see photo). Not sure if these are all normal occurrences or not, I'm running out of ideas. The machine is still under warranty of course, but if a tech comes out and we can't replicate the issue I would hate to be wasting someone's time.
