I just bought a Speed Queen wringer washer, 50's era, model F701. The bottom ringer at times doesn't turn. The bar thru the center of it does, but with heavy/thick clothes the actual roller stays in place while the metal shaft properly(?) turns inside of it. I've taken apart much of the wringer assy, greased and unstuck various parts, but still the problem. I am guessing that means the shaft and rubber roller is broken, unfortunately? I can't imagine that the metal shaft is ever supposed to turn while the actual wringer rubber stays still. Any advice? Any knowledge that indeed it is broken, not simply in need of tension adjusting/spring greasing? And any place I could replace that bar/roller?
Thanks
Mark
Other than that, the machine runs quietly and well, excellent turnover on heavy items, plenty of throw rugs, etc. I have the DeLuxe model, but as far as I can tell that just means there is a windup timer/bell that simply rings, does not stop any action of washing at all. Oh well! If any pro knows the standard versus deluxe difference, let me know. And I will wire in a switch, I'm a fine electrician, I don't like having to unplug it each time I'm done. Also, in replacing the 3-prong cord, it was already properly "green wire grounded" at the GE motor, which surprised me for 1950. Does that mean the motor has been replaced? Did they ground much appliances back in 1950?
That;s my numerous questions for now.
This website is great, but all I do so far is ask and ask. One of these days, I hope to gain some expertise and start sharing better. Each one teach one, I heard that idea somewhere.
Current collection is a 3 yr old Admiral toploader(Home Depot house brand BOL on sale), a 1974 Hoovermatic Twin Tub#0519, and now this wringer Speed Queen #F701. And a 40's Chamber's Gas Range. And over a dozen 30's-60's electric space heaters. Vacuums around here are whatever is cheap at an estate sale, I'm a slob who doesn't vacuum anywhere near often enough.
Thanks
Mark
