Spider Arm woes....
"Old" Bendix and Westinghouse washers had porcelainized steel tubs with huge heavy hubs cast into the back of the tubs with the tub shaft coming out of the hub. It was an altogether different form of construction than is employed in the construction of front loader tubs today. I can't vouch for the Bendix tub shafts, but in the 3 belt Westinghouse-design machines that only turned in one direction, the shaft could be unscrewed from the hub and replaced if bearing failure caused damage to the surface of the shaft. When Westinghouse had that bad run of seals that caused premature bearing failure, I remember John performing bearing replacements and, in one case, replacing the damaged tub shaft.
I don't think I could stand the thought of not using LCB
Well Mark, I've not put one drop of LCB in my Fridgemore (3.1 cu. ft.). I turn the water heater up to 155 degrees and use oxyclean. In fact, I quit using LCB in the Lady Shredmore and started a long soak with OxyClean. BTW mark, don't you use your Sanitize Cycle?--it should pretty much eliminate the need for LCB. It's just too caustic to machinery and damaging to fibers!!! In fact, my whites aren't wearing out as fast either now.
