Spin Distribution
Thank goodness for spin dryers, that's what I say
For loads one knows from experience the Miele won't like, simply cancel all interim and final spins, then chuck wash into spin dryer.
Tend to do this when washing smaller loads and or things that will cause the machine have large drum movements. Suppose could leave Big Bertha to sort things out on her own, and often she does to some extent. But again after putting >$500 between new shock absorbers and drum suspension (springs), this washer must last several more years to get ROI.
For large bulky items like blankets it is either off to laundromat or haul out the Maytag wringer.
Reply #16
Interesting.
My Panasonic was washing a load of 4 bathtowels, 2 handtowels, 3 cotton t-shirts, and about 6 pairs of socks on the Cottons 60 deg with 1600rpm spin. Not stuffed full, but about three-quarters of the drum.
The spins between the rinses never happened, extra rinses were inserted.
The final spin was nowhere near the set 1600rpm - it seemed locked about 1000rpm.
When the machine finished, I wasn't happy with the spin efficiency. I reset to spin at 1600rpm - same result, reduced speed. I repeated it again. Again the same result.
Today, I washed a half-load of a pair of jeans, various t-shirts and underwear. The machine performed a fast spin quite quickly.
My machine seems quite incapable of handling a full load of cottons at the specified speeds. I'm not impressed.
Here's the problem.
Force is mass times acceleration. Centripetal acceleration is equal to v<sup>2</sup>/r (v=speed, r=radius)* so there's your problem right there: We're talking one heck of a lot of energy to go from a lower spin to a higher spin.
Never mind the enormous amount of energy the object being spun has even at a very slow spin.
Manufacturers can either dimension the machine to handle the tremendous structural load caused by an out of balance spin or use logic to prevent the machine being loaded beyond what a cheap structure can handle.
How they find the right combination between structural components, logic, sensors, anti-vibration devices is all about profit and loss.
Ancient belt drive Whirlpool washers nearly never went out of balance - their mass compensated for just about anything. Ditto the 1970s AEG 800U/min and today's Miele washers. Which also use better logic and sensors.
Pay more, get more. Pay less, get less.
Unfortunately, the manufacturers are locked into a mentality of pay more, get less when it comes to beefing up their machines to handle the spin speeds they're promising.
*Before we get into another hysterical centrifugal/centripedal, velocity/ acceleration/speed nonsense discussion, just know that I could not care less and we all played that stupid game 14 years ago. Go look in the archives if you're feeling that 'a'-retentive. The rest of us just want to have some fun.
"manufacturers' mentality of pay more, get less"
Yes, that seems to be the case these days - right across the board. Everything is flimsily made.
Well my Maytag Centennial HE TL wasn’t an expensive washer and as far as spinning and balancing dependably it performs just like a washer from the old days before so many became particular about performing these essential functions.
So I don’t neccesarily agree that it is all about how much you spend. The load that I described as always having problems spinning in my 10’ Cabrio wasn’t a large or especially heavy load, and no other washer that I’d owned in the past ever had problems with the same kind of load.
All I do know is that I’m very pleased with this Maytag. I hope that I can get many years of good, trouble free service from it, time will tell. Its now over a year old, and in that year zero problems, so thats a good sign already.
Here is a full load of colors that I washed this morning and just finished folding:
2 pairs of mens jeans
4 crewneck sweat shirts
1 short sleeve tee shirt
1 heavyweight long sleeve tee shirt
7 pairs of black socks
1 handkerchief
14 cotton dinner napkins
2 placemats
This load was washed on heavy soil, deep water wash, hot water and it finished in 50 mins.
Eddie[this post was last edited: 12/21/2017-13:36]
Panasonic
This is one of many reasons I got rid of my Panasonic FL machine - the painful distribution. Frustratingly, it would be perfectly balanced or so it seemed to me, and then it would go into a further distribution and mess it all up again so off it went into another 10 minutes of distribution. I can see that from a wear and tear point of view with a larger load at a high spin speed (mine was 1400rpm) it was protecting the machine and I do understand the logic but as a user, my goodness it was irritating.
I replaced it with the same machine that the Panasonic replaced, a Bosch WFF2000. When it spins at 1000rpm it is as stable and as solid as a rock.
Oh, some machines do get it right
I had a neighbour in Munich who had an ancient Candy. One of those which used the variable pulley arrangement. She never had trouble with it, apart from replacing the belt every few years (a result of the mechanical load 'sensing' system). Those springs and shocks and variable pully Candy washers were the perfect balance between cost and effect.
I'm overjoyed that Whirlpool has got it right in their Maytags. Presumably the same system will now work it's way down the price-range until even Roper/Estate/Kirkland do the same.
Panasonic
It is so frustrating, it's beyond belief! A 10 min spin turns into 30 mins.
The previous machine was also a Panasonic - but with a tilted drum. Usually, the laundry fell towards the back of the drum and would get into balance very quickly - so a 10 minute spin was just that - 10 minutes.
This current heap is needing a bomb under it.
Panasonic
Rolls Rapide, what model Panasonic do you have now? Mine was a NA-147VB5. I believe they were made by Vestel. Amongst the other things that irritated me about it were:
The length of cycles
Timed fill
Pointless cool down at the end of a hot wash
2 rinses as standard
Pathetically useless wool cycle that was less effective than hand washing
Inability to spin single hand-washed items due to sensitive distribution
And I grew to loathe the smoked plastic door covering
On the plus side, when it did get around to a high speed spin it was VERY good and it was extremely quiet. It was highly effective at stain removal and once the wash was over you could open the door immediately. One might think that these things might negate the others but not for me.
Panasonic
I've currently got the NA-168XR1. Made in Slovenia, by Gorenje.
My peeves of my machine:
Length of cycles is bloody awful - no wonder the fabrics wear out. The time recalculations are just weird. For example, a small load flashed up as 1hr 50 at the start of the programme, and I presumed it would reduce as the time went on. Nope, ten minutes later it re-adjusted to 2hrs.
Filling time isn't bad, it does top up as it goes.
Rinsing: virtually every load, interim spins are deemed unattainable, so extra rinses are inserted instead. I'm sure that on at least one occasion it did 5 rinses! And in most cases seems to do 3 or 4 rinses.
That Woollens programme is thoroughly useless - virtually no turnover. If it wasn't for the pumped jetsystem, the garments would still be dry. And whoever heard of spinning woollens at 500rpm? Hoover of the 1980s had the right balance of woollen agitation and 800rpm spin.
Spinning is completely crap as previously mentioned.
I have a conventional clear see-through glass door, but the champagne matt plastic door trim looks decidedly underwhelming.
The drum metal is very thin and tinny - it rings like a bell when knocked.
I don't hold out much hope for the drum bearings. Several times, at the end of the cycle when unloading clothes, as I rotated the drum, I've felt a slight vibration and felt and heard a faint 'clunk'.
The old tilted drum Panasonic was NA-16VX1, made in China. It was a smoked-door machine, with a weird plastic cover over the drum bolts (inside the drum itself). The 'fresh-water' spray jet on it, was dire to say the least. Woollens was crap. But at least that machine span well when commanded.
Distribution
Having had all kinds of small chasis machine (EU size, 24") here in Germany, it really is dependent on the machine.
Our Panasonic had a huge tub with verry little space and - at least for high speed spins - a verry sensitive balance detection. It would distribute for up to an hour before giving up. It had 2 400rpm spin burst before its main final spin and these always went through perfectly. The final spin had a verry narrow balance window for noise reasons and only ever managed to spin with verry easy to balance loads.
I had other washers (like our current AEG or the Mieles) which spun high or even higher and spun nearly every time directly with no issue.
The suspension is only one part of the story. It has to be only stif enough to keep the drum form moving to much during low rpm stages of extraction. During high rpm stages, the drum can't move much of a distance anyway, so if the suspension is t stiff, to many of these high frequency vibrations are transmitted to the cabinet making for a rattely loud spin. To soft and it can't balance for low rpm stages.
Distribution algorythms are another.
Our current AEG has a pretty good spin preperation pattern. It tumbles 6 times, 3 times clockwise, 3 times counter clockwise. It starts with a tame 30rpm tumble and steps that up gradually to distribution speed during these tumbles. This pulls larger items apart gradually, allowing them to distribute better. In between spin burst, it stays at distribution rpm so it dosen't have to redistribute if it dosen't have to.
On the other hand, Hotpoint is and was a contender for the worst distribution on their Aqualtis range.
The machine would start tumbeling in on direcion, distribute, check for balnce, and if it wasn't satisfied, it would slow down but keep tumbling in the same drection, just distribute again, over and over. As it only reverersed once in a blue moon, the load would become more and more tangled as it treid to balance, only makeing matter worse with time.
Another thing is the padle design.
Asymetric drum lifters are designed to move larger loads from front to back slowly, which really improves cleaning as it moves items that would be usually stuck in the center of the load on larger loads to the outside and back to the middle again. Sadly, that also makes for a huge tangeling issue. Like, immense tangeling with large items.
And then there is how the machine actually senses for OOB situations.
Some machines only rely on accelerometers. These actually look for movement.
Some machine use motor current draw or motor rpm patterns at a current power supply.
Some use both in combination.
Depending on that, some can handle some loads better then others.
For example, really heavy items can startle motor based OOB detection. For example, towels don't tend to tangle much in my experience, but they are heavy when soaked.
Now, the load might look pretty well distributed, the drum dosen't sway much.
A motion sensor based system will greenlight the load for spin no problem.
Because the weights involved are high, even the apparently well balanced load will pose a verry high current situation to the motor, making the machine act more carefully.
Now, a brushed motor is much less accurately judgable for current as well, but machine with brushed motors are usually in the cheaper price region, so structural integrety and further sensor are less common on these machine as well. Thus, a machine that is not well equipped to judge loads on their balance is usually even less capable of handeling themand thus has to be even more carefull.
In general, there is nor ule of thumb what to look for in a machine.
Best way to know: Look for reviews.
For example, LG had huge balancing issues on their early generation TurboWash washers, making them less "turbo" then most wanted them to be.
They however ittereated their programming and solved some but not all of the balancing issues.
Another good example for the US were the Samsung made Maytag machines. Horrible machines in general, but especially for balancing.
Currents Samsungs don't seem to be the best either.
On the other hand, Electrolux seems to be decent with their - as they claim - learning balancing algorythm and their second floor guarante.
WP seems to be OK with hicups from time to time.
In the EU, currently, AEG as well as BSH seem to be decent.
AEG is a little more shakey, but spins without any mayor redistribution issues in my experience.
BSH seems a little quieter, but little more carefull for that matter.
Miele is as always leading, though their W1 series is certanly more sensitive then previous generations and seems a little more less Miele-quality in general with some minor issues which just should not happen on 1000+€ machines. (One that I read about for example is that - just as with SQ - a pump that burns out can potentially take out the main control as well, which just is bad construction in my opinion).
Of the cheaper brands, I know Gorenje to be OK. Not good, not bad.
Panasonic still has issues.
So does LG and Samsung.
LG washing machines
Hi All,
Thought I would input my experience with LG.
I purchased an LG washing machine this year 2017 and I am very impressed with how LG spins at full spin speed everytime it comes to the spin. Okay, it may sometimes spend a few minutes tumbling and attempting the spins to ensure its safe to spin, but I can always guarantee it WILL spin at full spin speed, regardless of whats inside it.
Most of the time its not fussy with balancing the load and it will just go into spin. I'm aware that LG have not always been like this though, so they appear to have updated their programming.
Ive seen this behaviour on 3 different types of LG washing machines available in 2017.
I had a Hotpoint Smart in 2015 and that was a terrible machines, would frequently abort the spins or have a slower final spin. Even though it would rotate clockwise and anti clockwise to try and balance, it would always be fussy on every single cycle, adding more time to the wash.
I really rate LG for their technology and the tumbles are always fun to watch. I just dont rate them on their quality control. Ive had issues with 3x machines having a fault where the Turbowash jet does not spray the load. Never knew if that was a valve fault or a programming issue. Got a refund on those. I then experienced an issue with having 4 x LG's delivered with dents on the back panel - this was caused in the factory on the conveyor belt or when the machines were boxed or moved in the box. Other than that, I think their spins are excellent and its nice having a machine that always spins on each cycle and at the full speed.
Better machines...
So it seems that LG and Electrolux are largely the best machines in regard to spin distribution, with Whirlpool not too far behind? I wonder if the current Frigidaire machines are getting the "learning algorithm" as hand me down from the new Elux lineup.
At the moment it seems like Electrolux is giving a lot more machine for the money. They come with that extra mixing chamber for detergent and perform better on CR tests than other machines at the same price point. LG turbo wash is really the only reason I would step up from Whirlpool as it seems like they've both got those unique wash actions. I am sure that Whirlpool will outsell Elux since they generally end up being deeply incentivized at most big box stores...
Reply #31
It's interesting that Hotpoint (Indesit) frontloaders should be such rubbish balancer/spinner, because I'm sure I remember reading some article (maybe 10 years ago?) about Indesit toying with the idea of having one of the tub's shock absorbers being replaced by an active actuator type - which could adapt the stiffness of the shock absorber 'on the fly', from feedback from the balance sensors etc.
Apparently having one active damper/actuator in addition to the usual passive types, worked best, since two seemed to fight against each other. I think it was around about the time of the Indesit 'Moon' and the Indesit 'Prime' ranges.
I can't remember exactly where I read it, at the time. It might have been in one of those 'technology magazines', or it might have been one of the Trades publications like 'ERT Weekly'.
I can’t offer much brilliant insight here...
But I have observed this about front loaders. We had a Frigidaire/Kenmore front loader set for several years (moved and left the set, new house came with ‘Shredmore’ set) and it would sometimes take a good long time trying to sort out how it wanted things in the tub. I’ve been around an Asko set too and it didn’t seem to take as much time, bu t it still took a minute or so. I was really shocked when I first saw a Speed Queen run it really just seemed to go from agitation to spin with no real sorting out the load balance. It shocked me and I was expecting a more violent spin, the tub does seem to go for more of a ride than the machines that spend more time on the load balance, but the machine itself stayed steady and there really wasn’t much if any of a shake rattle and roll routine... same goes for the Asko though it never seemed to go too crazy. Now I know someone with a Whirlpool Duet that walks all over the laundry room, but that’s going to be a whole separate repair thread if I can ever get around to that...
