Update
Last night I returned from a weekend trip to the bay area (San Francisco) and of course have a nice pile of laundry. I did two small loads without incident. Anyway, since the serial number is conveniently listed on the inside of the lid, I decided to finally register it since it's already 4.5 months old. Mike had a great suggestion which was to call Alliance. Well, since I was registering the machine on the website, I instead sent a message on their support page, and actually got a response. I do appreciate when companies respond to such inquiries. Anyway, for anyone interested, here is their response:
On 02/27/12, Matthew Anderson wrote:
Hello Leonard,
Thank you for your purchase of Speed Queen Home Laundry. The model AWN432SP111TW01 does feature a thermal overload in the motor. If the motor was to overheat the thermal overload would shut the motor off to prevent damage. There are several things that could cause a motor to overheat, including overloading of the machine or the agitator becoming jammed. The thermal overload will stop the motor to protect it from damage. If it has only happened once it is not a concern. If it should continue to happen then I recommend having a servicer out to look at the washer to determine if there is an issue. The warranty on your washer is as stated on the attached warranty bond. 3 years parts and labor on the complete washer, 5 years parts on the motor, 10 years parts on the transmission, 5 year parts on the cabinet assembly against rust from the inside out, and lifetime parts on the stainless steel inner tub.
Thanks,
Matt Anderson
Alliance Laundry Systems
Technical Support and Service Training
Laundry, it's all we do!
-----Original Message-----
Sent: Sunday, February 26, 2012 10:55 PM
Subject: Speed Queen Customer Service Contact Form
First Name: L
State: CA
Zip: 91709
Country: USA
Email:
[email protected]
Model Number: AWN432
Serial Number: ***********
Comments: My washer was installed on 10/08/11 (though I just registered it tonight). This last week I had a problem. I washed two loads, and on the second I had two pairs of jeans, a polo and perhaps eight pairs of socks, and I had the water level nearly at the highest setting. It didn't seem like I had overloaded it, but I walked into the wash room and found that the wash water was still in the tub.
The dial looked like it was between wash and spin so I figured it was about to start spinning, but after putting the lid down, it didn't seem to do anything for a long time. Also, I noticed an electrical burning smell. I pushed the dial back in, turned it back to the wash, pulled it out, and nothing. I tried a few more times, but nothing. Wouldn't even fill more when I put the water level to max. I stepped away for a while, came back, then it started.
Reading my manual, I did see that the motor has an overload protection thing that may shut it down, but since I don't think the machine was overloaded, I'm concerned.
I selected a SQ because I wanted a durable strong traditional top-load machine, but I'm concerned. What is my warranty, and what would you advise?
Thanks,
-L
