Noisey Main Bearing On A New SQ FL Washer
I do have some dough about a noisy bearing on a new SQ FL washer, but it is possible. I would keep using the machine and see what happens. I have seen cases of a noisy sealed ball bearing in various types of washing machines and it usually does not get worse for years and years and years, almost all bearing failures are caused by water getting into the bearing area and in this case the failure will occur fairly quickly.
If you wanted the complete machine replaced you would likely have to talk the dealer that sold you the machine into doing so. If I was the dealer that sold you the machine I WOULD NOT replace the machine for you as the complete bearing and seal assembly can easily be replaced in the home. This is one of the beauties of this FL washer, not only does it have a great warranty but it can be easily repaired WHEN something goes wrong and like EVERY washer, automobile, etc ever built something will go wrong sooner but hopefully later.
