a3620
Member
Evening folks, I wonder if anyone can point me in the right direction?
Our wonderful old Square Door A3620 Hoover Logic 1300 has stopped spinning!
I fitted a new "old stock" motor 18 months ago while fitting new bearings etc.
All of a sudden, neither the G 1300 spin or the N 600 spin are working.
The drain pump is working properly and all other programs seem to run as normal.
I’ve tried gently rocking the program knob but the drum just turns at the normal wash speed.
I removed the motor brushes, they have plenty of meat on them (only 18 months old of course) they move freely and the commutator looks mint.
I put my meter across the tachometer, and the meter fluctuates as I turn the motor by hand. Admittedly not a conclusive test, but it suggests continuity. I also checked all the spade connectors etc.
Took out the motor controller board and couldn’t see any obvious dry joints etc. Again, I know this doesn’t mean it isn't faulty.
Finally I re-seated and checked all the plugs on the timer/motor etc.
Normally, I would just buy a new motor, but it's reasonably new. Could it have failed so soon?
Ideally I would start substituting parts, but this is obviously impossible with the now rare and expensive parts, so I'm unsure what else I can try?
I don’t think it’s the timer, because neither 1300 or 600 programs work and I would have thought a "dodgy" contact would have shown up as an intermittent fault. Am I wrong?
I'm tempted to buy another motor. Question is, do these symptoms sound like the motor controller, or the motor itself, or am I barking up the wrong tree entirely?
Is there anything else I could check, or should I just ring the scrap man?
Thanks in advance
Chris
Thanks in advance
Chris
