toggleswitch
In the living room I installed this valve (brass with red handle) below the air-vent valve to keep the radiator cool.  The radiator, once cooled off, will not re-heat.
In order for steam in a one-pipe sytem to enter the raditator, air must be purged. It is this valve's function (i.e. the upper chrome thingy) to stop the steam from escaping, one the air has been purged. It is a simple mechanical, thermostatically-operated valve.
The aluminum foil here is just used to show that it can be used to limit heat! I now tend to use the red-handled valve!
Eventually I will extend the air-vent pipe/tubes to outside of the "radiator" enclosure and place a Danfoss-type automatic mechanical thermostatically-operated valve that respond to room temerature to regulate the heat output of this and other units in the apratment. [this post was last edited: 11/13/2010-00:44]
