Probably should move some things on
Maybe mark them up and sell them on....
Bought a NIB Presto fancy jet vapor steam iron; used it once and that was that. Went back into box and has been sat sitting ever since.
Ditto for a Rowenta huge iron from 1980's...
Both still had the labels on their soleplates, never touched, etc....
Also have several NIB but used older irons like a Presto dry iron, Eureka cordless, Westinghouse open handle, and could go on. All never see really much use.
Tend these days to go for my Sussman Aquamatic pressure steam iron, or the large steam boiler iron. As such the rest are sitting round gathering dust. Do use the dry irons sometimes when doing linens, but even then prefer the Sussman.
Naomoto gravity feed iron that hasn't been used in ages as well.
I like older commercial/industrial irons (have a Cissell and Hoffman too) because of their heft and mass, usually via a cast iron soleplate.
Once one gets used to the weight it works a treat. Also the mass holds heat so the iron remains rather constant in temperature. This is important when dry ironing damp linens since the cold surface of fabrics cools the iron. You notice this with irons that have temperature indicators how the light goes on and off.
Largest regret is getting suckered into the older vintage Presto "Vapor Steam" irons shown below. Have three (one was NIB) and really aren't that thrilled.
Consumer Reports hated these irons and constantly rated them "unacceptable". First and foremost the steam never stops. All that superheated moisture continues to stream out of the iron long as there is water in iron. On warm or humid days it makes ironing that much more unpleasant.
