Steve, my KDS-14 has a quirk- on the drain cycle.
sometimes it doesn't drain, the solenoid clunks but no water comes out.
I replaced the drain hose as the former had a 90degree elbow in it, now when it does drain the water almost shoots out of the disposal! But it doesn't always drain and if I dont' catch it early the prewash water will travel all the way through to the final rinse! YUK!
If I stop the machine at drain and wait to hear a gurgle, then when I turn it back on the water will drain.
Can the drain valve plate come off the drain plunger shaft inside the valve??
I can see the plunger move out when the solenoid activates, but no water flows.
Mystified in Melrose
jon
jon
