Well there was me doing a bit of housework late last night including running the DW. Halfway through the pre-wash the Kenmore made an odd noise then the motor and pump stopped running. Nothing to be heard but a humming noise.
Now this unit had been making odd noises now and then for awhile now. Didn't really bother as one figured the portable dw is nearly 20 years old and just getting on.
Moving the timer dial around produced nothing in the way of restarting the motor/pump. Unit will fill, but no washing or draining, just that blasted humming sound.
A quick run to the computer, plugged in some information and one came up with a few possibilities. One being the pump and or motor, the other being shaft/seal assembly.
First order of business was to get the dishes sorted. So there one was with hands in hot water doing something one has not done in ages. Doing the washing up by hand for several place settings.
Next siphoned out the water from the bottom of the DW and after disconnecting the water/drain hoses wheeled the thing back to its resting place. That is when one noticed a pool of dark brownish mucky water from under the DW. Ran for the Bounty and upon closer examination saw the black bits one assumed were food, was shreds of plastic. Well that's me for you, this DW is probably going out on recycling day. May try to get some parts off the unit such as the unicouple hoses, and maybe the timer.
While the motor is officially NLA for this Kenmore (built by Frigidaire/model 587) 18" DW, there are other sources for either used or NOS. However they run about $200 give or take. The seal shaft assembly is still in stock from Sears and other sources and is a bit more reasonable at around $40. Still after labour and callout charges one is looking at a bill of perhaps $200 to $300 or more for a 20 year old dw. New Sears has them currently on sale for about $530.
Reason one is leaning towards chucking the machine is also there was some sort of burning plastic/wire smell inside the DW after one had turned the dial a few times in an attempt to get things going again. This could just have been the motor burning itself out because it cannot move, or something else.
