Stuck spanner nut -- Maytag LAT2600AAE
RoseRed
Mar 6, 2016
24
Hello, hoping to get help.
Purchased a Maytag LAT2600AAE that had been sitting unused for close to 2 yrs. Gave it a test run and it seems to be running ok. What I did see was that it had fabric softener/detergent all over the tub ring. Removed the front and flip up the top and saw that it was going to be much more than just scrubbing the tub ring.
Removed the tub ring, and agitator, found a mound of hard white stuff in the center all up to the spanner nut. Wire brushed the area and cleaned it best I could. Got the spanner wrench and banged clock wise, but the nut won't budge. The part (spanner washer) under the spanner nut is rusty so I think that is part of the problem. Sprayed some PB-blaster on the spanner nut and letting it sit over night. Will try banging it out again in the morning.
The filter at the bottom of the spin tub was covered with and "glued" on by the white stuff, but I was able to pry it off, and took a couple of hrs of soaking in vinegar and scrubbing to get it clean. There is white residue covering the bottom of the outer tub and caked on white residue between the spin basket and the concrete counter weight.
If I can't get the spanner nut and spin basket out to give both tubs a good cleaning, would adding something like LemiShine to a hot wash break up the stuff stuck to the inside of the tubs to clean it out. I've also read adding a quart of bleach to a tub full of hot water and letting it soak for 1 hr than let the cycle complete. The same procedure is followed but the second time with 1 quart of vinegar.
I welcome any help in getting this washer cleaned up and doing laundry.
Been spraying PB-blaster/WD-40 and hammering the spanner nut till my ears hurt. Still won't budge. Said to husband that I needed a cold chisel to try and cut it out. He already was not happy that I bought a used machine. Said to take it as a loss get rid of it and go buy a new washer. Was thinking of calling in one of the local repairman to have him do the job, but I'm sure husband would not go for that either.
Can't you -carefully- heat it up with a torch? It helped removing a stuck pedal on a Shimano bike crank for me.
Yeah, a blow torch/dryer will often help with freeing up stuck parts.
Others will have to confirm one way or another, but could the spanner nut have a reverse thread?
You might try punching applicable terms into the "Super Searchalator" option at the top right of the forum index page, below the regular search field, to see if there are any old threads with helpful information.
@Askodude
I don't have a torch and husband doesn't want me to spend any more money on the machine. I have to make do with what I have on hand.
@vacerator
I think I remember seeing a can of Liquid Wrench in the storage shed. Will look for it and try that.
@rp2813
From previous readings, with this Maytag the spanner nut is loosened to the right (clockwise). I'll recheck. Blow dryer is that meaning a hair dryer? I do have one that blows quite hot air.
Left-Hand Thread
One of our local experts has confirmed you should be tapping your spanner wrench in the clock-wise direction, for this particular washer.
LOL I guess if you are going to work on washing machines, you have to be informed enough to be capable of doing it!
@appnut
I am way down south, in the RGV.
I want to try something before going any further. I tested the washer in place where it had been sitting unused for approx. 2 yrs, after the seller's father went into a nursing home. Used cold low water settings. Don't yet know how the washer is going to function with a full load of water.
I've been working on it in my back porch. I am thinking of connecting the water supply hoses to the washer. Connecting the hot to a garden hose going to the hot water supply in the laundry room. The cold to the outside garden hose. I have 2" pvc pipe and an elbow that I can use to rig up a drain. Normally one should not use an extension cord to power a washer but I would need to use one to reach the electrical outlet. I have a 9 ft. 14 gauge appliance cord. Would it be ok to do like 3 hot wash runs using the appliance cord. I don't want to set the washer up in the laundry room at this time, in case the pump or something else goes and end up with water running out of the washer in the laundry room.
I'm thinking the hot water with 2-3 cups of vinegar may also help to loosen up any sediment that may be "gluing" the spanner nut in place.
Depends on if the extension cord is heavy enough for the length.  I had trouble with running some Maytags (A206 and A608) via (too light of) an extension cord, the motor had trouble under load getting up to speed to drop out of the start winding.
I'd expect PB more likely to help than a vinegar soak.
Success, success - the spanner nut is off. Had a trip to Lowes today and since I was there checked what they had and bought a can of WD40 Specialist rust release penetrant spray. Sprayed the nut and about half hr. later pounded on it a bit, sprayed again. This time waited maybe 2 hrs and gave it another go. At about the 3rd or 4th hit it broke free.
Don't know if it was the WD40 Specialist itself or the combination of penetrants used. I am just so glad the spanner nut is off.
Now to the spin basket, it looks to be stuck at the center. Is it ok to spray the center area?
Connie,
My dad always changed every seal or part that touched an old one. New parts work best with other new parts.
But, if your rubber seal looks good, with no tears, or wear, if you can get just the cork gasket, why not?
Once dad was rebuilding an old belt drive Whirlpool spin tube and clutch. He used new oil lite bearings. I asked why. He told me because even thought hey bleed oil as they spin, if they are worn too thin to fill up the space between the agitator shaft and spin tube, both would wear faster, and would be loud.
As he did not have a micrometer to measure their thickness, he replaced them.
Good as new!
After spending quite some time chipping away at the concrete like calcified layer covering the bottom and sides of the outer tub, the problem with the cork gasket and still not knowing whether the washer is going to work, decided to throw in the towel.
Thanks to all who gave me advice on this venture.
