How Many Ways Can You Say....
Dumb-Ass?
Tom & All:
I'm out on a trip now, but as soon as I get home I will do as you say..
So, the gasket is held to the upper vessel as the metal center of the gasket acts like a "washer" between the screw threads of the water cone and the bottom of the top vessel. I get it now! The cone is what actually holds the gasket to the top vessel! But I don't see an "O" ring between the water cone and the top plate. Is there susposed to be one there? It looks like the seal between the top of vessel and the gasket assembly is so tight, one would not be needed.
I feel rather stupid too..... It all makes perfectly good sense...now!
I usually pick up on these things, and now that I have re-read your thread, I was just not understanding what you were trying to tell me. I honestly didn't know where my mind was when I was reading your posts.....
Actually the person who I bought it from sent it totally disassembled with no instructions for assembly, so I had to guess on my own. At least I know my unit is clean and I really wonder if the unit was ever used, it's so clean. I can see too that if you don't disassemble it periodically you could get who knows what growing in the seams between the gasket and the vessels.....
I really had a good laugh when you said "Nobody uses a Coffeemaster your way". How true! I can see how my procedure is NOT RECOMMENDED! Those Coffeemasters get so darned hot! I am sure that they couldn't be made again today as I think the exterior of the unit gets way too hot compared to today's coffeemakers. But the heat is probably the key as to why it makes such good coffee!
We used it again this morning and we just use 4 layers of cheesecloth with each layer 90 degrees to the other. It makes for a perfect filter. We don't reuse it, we just toss it and cut out a new one from the roll of kitchen use cheesecloth. There are absolutely no grounds in the bottom pot when done. But I did buy the optional metal screen on Ebay the other day, so I don't think I'll have to get the cloth filters.
