Sunbeam Mixmaster Gear Oil
waterstreet
Oct 12, 2006
46
There was a recent post that gave advice about the type of oil for Mixmaster Gears and how to properly top off the gear box.
Since that was posted, I have found this charming Model 7B at a local thrift shop. It seems to work very well - and I would like to insure that the gears are properly oiled. If you know about these things, I would appreciate your reply.
David
More on gear oil
Laundress thanks for the response. Since my post I spent time on a web search and found this care sheet.
Unfortunately “Special Mixmaster Lubricant” is no longer available. I suspect a good automotive wheel bearing grease would do.
I tried to follow the simple steps to inspect the grease compartment, but the flat head slotted center screw did not turn easily. I need to get a slotted screwdriver and grind it to exactly fit the slot and try again.
Again , thanks, David
Over here...
Kenwood do a special "food grade" grease for the Chef gearboxes- I dont know if maybe Kitchenaid do anything similar??
Seamus
RE: Over Here
A "food grade" grease sounds like an excellent idea. I will follow up and see what I can find.
Thanks, Seamus
Grease
Just ordered a tube of Food Grade Grease from a food service products retailer listed on eBay.
Thanks for the help !
David
