Sunday Morning ='s Waffles
launderess
Jul 22, 2004
20,858
Have had a "NIB" vintage Son Chief waffle iron sitting my cupboard for years now that hasn't seen the light of day since it arrived from fleaPay. Well what with a bag of KA whole wheat flour sitting in the freezer and tons of eggs in the fridge (they were on sale), decided today is waffle day.
After seasoning the iron whipped up a batch of WW waffles that came out a treat!
Sorry no snaps but didn't think about it first thing in the AM when it's all body and soul can do to start the coffee! *LOL*
http://www.kingarthurflour.com/recipes/whole-wheat-waffles-recipe
So how did your vintage waffle maker behave, Laundress? Was it a pleasant experience?
I finally purchased a waffle maker about a year ago. While I'm usually a pancake person, there is certainly something to be said for a nice crisp-on the-outside-creamy-in-the-middle waffle. I made buckwheat waffles when I was eating a vegan diet, and they were always a treat. I should try to make them again---with eggs, this time.
Worked A Treat Once Things Settled Down
Being the first time of use had to figure out where to keep the temp dial set to produce the results desired. Of course as usual the first batch of waffles were instant scraps (had to be dug out with a fork and pastry brush), but after that things were swell.
Second batch made very crispy, second and last a bit less so. These waffles were so rich that more than two was impossible. So the rest will be frozen for a later date.
Several Secrets To Using Good Vintage Waffle Irons
With cast aluminum grids.
Most persons make the same mistakes with these grids as they do with cast iron cookware. They scrub the things clean after each use then try to "reseaon" which rarely takes fast enough, then wonder why food sticks.
After proper seasoning cast alumimum waffle grids are like cast iron; Do Not Wash/Scrub Them In Water, Ever. No, just don't do it!
All that is required is a wiping down with a damp towel (cloth or paper) and that food bits are removed. Next time the surface is heated up it will more than destroy any "germs" if that is what worries.
Seasoning Cast Aluminum Waffle Grids:
There is one nearly foolproof method recommended by vintage waffle iron makers and even the US government going back to the 1940's. It still works today, so why tamper with sucess?
For a new or clean waffle iron take a clean cloth or paper towel and liberally apply cooking oil (canola or peanut is best, but any veggie oil will do), or shortening to the cold plates. I use a pastry brush but however the thing is done use lots of oil.
Close the unit up and set it to the highest setting and allow to heat for about one half hour. After that time has elasped turn off the iron and allow to cool. Once cold open the iron and place a clean towel or paper towel onto the bottom cold plate and close the unit up. Allow to sit for a few hours or overnight and remove the towel before use. The towel will absorb much of any excess oil. Your plates should now have a brownish sort of coating, and that is what you want. Once properly seasoned one shouldn't have to apply coats of oil again before each use.
When using waffle iron turn it on to the proper setting for at least one half hour before use to allow for equalising of temp. Many irons have cold spots and this gives time for the entire plate surface to have a nice even temp. Square shaped plates in particular are famous for having cooler corners than center. This is one of the reasons serious waffle professionals always recommend round shaped waffle irons over square.
Butter Belongs In The Batter, Not The Waffle Iron:
Butter has a very low burning point and will smoke and break down long before the surface of a waffle iron is hot enough for making good waffles. This is very true of vintage cast iron or alumimum waffle iron grids that get quite hot. Pure butter will smoke and burn long before the grids get any where near the right temperature which causes most to turn down the heat, this means the grids never get hot enough to make good waffles. What usually happens is the batter sticks and the resulting waffles do not come out without being broken apart into bits.
Veggie oil in particular canola and peanut have higher smoke points thus can withstand high heat for long periods. This is why they are first choice for frying foods.
Butter may be an acceptable choice for newer Teflon coated waffle irons as they do not reach very high temps.
Which brings us to anohter point. For waffle batters that call for all butter, try replacing some or all with veggie oil or shortening. Waffles are crispier and tend not to stick.
Personally, since our waffle maker has removable plates, (1960's sunbeam) I just remove them and run them through the dishwasher after using it. Then the next time, after it has preheated, I spray it with butter flavored cooking spray, and after every set of waffles. The waffles never stick and have a buttery flavor.
Again, That May Work For Some But Not Other
Waffle irons/makers.
The waffle plates on mine are made from cast alumimum which would be destroyed (well turn a horrible black) if washed in very alkaline substances and or the dishwasher. Suppose if one could find a dw detergent that was netural and or designed for cleaning such metals....
Hmmm, Could Be.
Am at loss to understand the need to scrub up waffle plates after use. If the waffles come off cleanly there shouldn't be anything but a bit of crumbs to deal with, and maybe not even that. Any remaing food residue should burn off the next time the thing is heated.
As for cooking sprays, rarely use them at all except for perhaps grilling. Found they left a coating on one's baking pans that wouldn't shift.
To grease baking pans and such keep "old" Crisco or other shortening around. Sometimes follow an old method of making homemade "Baker's Joy" by combining shortening and flour for a ready made product to grease cake pans.
Well, I thought I would jump in here
Just bought a couple of waffle irons, didn't need them, but they were in good shape and the price was right. This one is really old, but makes fine waffles. First to last they were great.
This is the new daily driver, though
This GE is in great shape. I have a few recipes, and the one that calls for the whipping up of the egg whites makes the lighter waffles, but I am usually too lazy and just make the simpler recipe and they taste fine.
Got this at the Goodwill outlet for a song.
Old daily driver - its a Hoover!
Have used this one for years but it is not in such good cosmetic shape, so I prefer the like new GE. I still use this for hamburgers, grilling etc. as the shape is better and that process does mess up the little appliance anyway.
Whipping Egg Whites Separately
Goes back to making waffles since the first electric models appeared, and probably before. Early Toastmaster waffle makers came with a basic recipe that is still handed out/used today. Indeed most all basic recipes for waffles are rather the same, and all usually call for whipped egg whites. The recipe which came with my vintage waffle iron says to use egg yolks and whipped egg whites.
Rationale is simple: like pancakes, corn bread and other "quick breads" you don't want beat waffle batter too much after the liquids have been incorporated. Folding in whipped egg whites allows for a light and fluffy waffle, or pancake for that matter.
Some people find it is too much bother to whip egg whites and prefer one bowl batters for waffles. Indeed one of the reasons many are turned off to the idea of making waffles is the preceived amount of time and effort that goes into making the batter, then one has to deal with making the waffles.
The other tried and true method is to use "sourdough" starter or "yeast" waffles. Personally one does not have that kind of time to make a batter the night before or at least several hours.
Love That GE Waffle Maker
Sunbeam also had a "small" unit that looked almost exactly the same.
Am going back and forth about getting a second waffle iron that also doubles as a griddle for making flap jacks or sandwhiches.
My current unit comes with plates to swap out the waffle grids with to become a sandwhich press, but highly doubt it would work as a griddle. Too small for a start.
Think a cast aluminum or iron range top griddle would be better.
2 Step
Fold in the egg whites makes the outer surface of the waffle crispy.  Waffles made without whipped egg whites are softer and more cake like.
Sunbeam Will Come As No Surprise
I add melted butter to the batter and NEVER grease the grids and certainly never let a LIQUID oil come anywhere near the grids.  Heating the iron in the opened position greatly reduces the build up of carbon on the grids.
60 Years Young
This waffler has been making perfect waffles for 60 years and has never needed to be reseasoned or cleaned.
"NEVER grease the grids and certainly never let a LIQUID
So what have you got against liquid oil coming near your grids? Or maybe I shouldn't ask? *LOL*
Spent the past few days reading upon waffle making via the Internet and the "pros" out there all recommended heating the waffle iron whilst closed. For my waffle maker the directions recommened heating the unit closed as well. Besides the indicator light for when the thing has reached proper temp is on the lid. If one left it open would have to keep partially closed the lid to peep. Since the lid like much of the rest of this waffle iron gets very hot, have to use a pot holder as it tis when lifting or closing the lid.
Never thought to get out any of my stand mixers for making pancake or waffle batter. Have a great vintage huge Pyrex glass "batter bowl" with a pouring lip that is great for mixing and dispensing batters. Don't really beat my pancake or waffle batters long enough to warrant dragging the Braun, Kenwood, or Bosch out and setting them up.
Nothing to Get Out
I leave the mixer on the counter so using it is actually less work than getting in the cupboard and drawers for bowls, egg beater and spoon.  Oils carbonize at a lower tempertaure around 345 degrees and solid fats like shortening and lard can be heated to 365 before carbonizing. Carbonizing equals sticking and smoking.  The batter will actually stick to the burned on carbon on the grids making it more difficult to remove the waffle.  Using sprays or brushing the grids with melted shortening will keep a waffle from bonding to the grids which gives the waffle a "pinto" appearance and added fats to the grid will continue to carbonizing making the whole issue of sticking worse.  Having worked in the industry as a chef and a manufacturerer's rep for Centenial Mills (Krusteaz) and General Mills, Kitchenaid, F.S. Carbon (Malted Waffle Batter) and  Lang we advise professionals in the industry to leave waffle irons in the open position between orders and when preheating to prevent carbon build up.
I have a Cuisinart waffle maker that makes 6 waffles at a time.  I use the recipe that was in the instruction book.  I have only used it 4 or 5 times but every time the batter oozes out every which way and makes a mess.  I keep cutting down on the amount of batter but still have the same problem...what am I doing wrong?  It takes me longer to clean up the mess than it does to make the waffles.
Gary
French Toast Stix
I bought a Cuisinart waffle maker that was rectangular and made six waffle stix and it came with small cups for syrup and dipping sauces.  No matter how hard I tried the batter seemed to ooze and run out in some areas and leave blanks in others.  I finally gave the waffle iron to Goodwill.  I have had three Begian waffle makers, two Cuisinart and one Calphalon and the Calphalon which is a poorer relative of the All-Clad family was nearly perfect in every way.  At the end of the day I liked thinner and crisper waffles better and went back to using the Sunbeam on a regular basis.  Everything I have said about waffle irons, liquid oil and sticking go out the window with teflon waffle grids.  I still don't use any additional oil because I like the evenly browned, crispy crust but seasoning isn't an issue with non stick grids.  The Sunbeam waffle iron I use on a regular basis is from the early run with the cloth cord and it does have interchangable grids.  Sunbeam waffle irons have more points on the grid per inch than most brands which makes a crisper waffle.  It can be a double edged sword becuase it makes a superior waffle but makes the surfaces area a waffle can stick to greater.  My life and career have been an adventure of machines, products, technology, education and people who make their life with food.  Some of what I say is pure, defendable fact, some is a product of trial and error and some is the colloquial sharing of many experiences from different cultures that all create repeatable results.  Adults are the hardest to teach because of our own bias and unwillingness to take any new information until it is demonstrated that there is a benefit for me first.
What to do with all this stuff????
Here is another waffle maker I picked up the other day. It runs a little hot but actually makes a very good waffle, very fast. It didn't have the old fashioned cord but of course I have a few extra so I picked it up. It had been used not too long ago and wasn't too cruddy at all.
I guess I will have to leave this stuff to various people through my will, if they want it.
I'd always wanted a waffle iron growing up, but Mother refused.  I finally bought one this year...I know I know, not a vintage appliance.  But it does make a great waffle.  It's the B&D with multiple removable nonstick(yeah right) grids.  Every couple of uses I toss into the dishwasher.  Waffles are a cold weather treat for me...hmmmm, what's the temp down to now?
It's national waffle day and decided to make some waffles out of our George Foreman maker. I'll admit, I do prefer the vintage waffle iron makers like the GE in reply #11. My grandparents owned one that used to belong to my great grandmother. Now with them gone, my uncle uses it and still makes excellent waffles.
