Basic front control, 29 inch dryers
These were made as mentioned from the late 60s into the 70s, it was mainly to get people into the store to look at a dryer. They were sometimes advertise for as little as $50 here in this area, and they tried everything in the book to get you not to buy it I did successfully buy one for a customer that had an old Westinghouse dryer that was beyond reasonable repair.
The first versions of this use the filter inside the drum like the portable dryer, but many had the lint filter on the top, which would make it hard to put it under a counter, it was also too tall to go under a standard kitchen counter, although you could raise a couple inches I guess .
This was a 240 V dryer although it only had a 4400 W heating element in it. The timer had a much longer max dry cycle so you could connect it to 120 V if you didn’t have 240 V available.
Many electric ranges and dryers are still hardwired. It’s actually much safer but codes require a disconnect switch within sight of the machine sometimes just being in the same area as your main circuit Breaker panel is sufficient to wire them in the safer more permanent way.
It would be very cool to find the combination washer dryer That Ben pictured I’ve never seen one of these. I suspect very few were sold most people that were gonna spend the money for a combination buught one of the better models. They also made a number of 24 inch belt drive washing machines with the same timer control on the front, this was also the low priced leader machine to try to get people to look at an automatic washer, but some of those were sold, we also saw a few of these dryers over the years. Nothing wrong with them at all.
Here’s a picture of a 30 amp dryer outlet that I saw burned up a week ago. This is what goes wrong with outlets and plugs sometimes and why it’s actually safer not to have this type of connection that could cause a fire as opposed to having the power cable directly connected inside a metal box. That’s part of the machine.
John
