washertalk
- Joined
- Oct 14, 2006
- Messages
- 837
I forgot I had these in my camera from yesterday.
I set out to do a small load of white socks and a sheet and descided I should take the groups advice and use the Sanitary cycle.
So I did a soak cycle first. I wear my socks in the house(no shoes aloud usually). So they get alot of wear. And I like them clean. so I did the soak with the standard amount of detergent. The same can be said for the wash. I wasn't planning to take photos but then things started getting interesting so about half way through the wash cycle is where the photos start.
After adding the longest wash time the computer literally read 2 hours exactly. This is the cycle that heats the water. I don't know if it uses a different water level measure. There wasn't much in here just like 12 pairs of socks and a sheet.
