suspicion that i have (not a complaint)
pierreandreply4
Sep 7, 2007
2,739
St-Bruno de montarville (province of quebec) canad
for the last few days i am starting to have suspicion if my daily driver maytag mvw6230hw2 do not have a major defect or if its not a faulty control board here the following yesterday i wash some bedsheets washer was set to hot water wash it sent in hot water then switching to cold might be normal but not sure, then regular load washer set to warm water wash no mix i am starting to question myself if washer itself is not defective since its not working like supose to i am no tech but in term of percent what would be the chance that it might be a faulty control board that might of been cause when washer was still brand new like the power outlet of the washer was replace followed by the washer faucet house pipe where the washer is connected. The reason i am thinking that is when the power outlet of the washer cause the washer during the spin cycle to stop leaving the lid lock it making me wonder if that has not affected the control board in someway washer will be 5 years old july 21 2025 to use the washer i had to use a extension cord (*might not be related but like i said in title i have suspicion) because its clear washer is not working like supose to
for the last few days i am starting to have suspicion if my daily driver maytag mvw6230hw2 do not have a major defect or if its not a faulty control board here the following yesterday i wash some bedsheets washer was set to hot water wash it sent in hot water then switching to cold might be normal but not sure, then regular load washer set to warm water wash no mix i am starting to question myself if washer itself is not defective since its not working like supose to i am no tech but in term of percent what would be the chance that it might be a faulty control board that might of been cause when washer was still brand new like the power outlet of the washer was replace followed by the washer faucet house pipe where the washer is connected. The reason i am thinking that is when the power outlet of the washer cause the washer during the spin cycle to stop leaving the lid lock it making me wonder if that has not affected the control board in someway washer will be 5 years old july 21 2025 to use the washer i had to use a extension cord (*might not be related but like i said in title i have suspicion) because its clear washer is not working like supose toI would assume defective.
Pierre listen to sound advice. Find yourself a good refurbished direct drive. It's worth it.
They have hefty motors.
Hey everyone,
I'm wondering if you all have any suggestions?
I have a GE/Monogram DW model ZDT870SSF0SS. There's nothing blocking the soap dispenser, the filters are all clean and I run the hot water before I start the machine and the soap never completely dissolves. I either find part of a pod or, as you see the the photo, there's detergent left behind. This was Cascade Complete powder. I usually use the Cascade Complete pods.
I've tried to take apart as much as I can to clean the interior and the jets. I'm constantly wiping out the machine interior and it's quick to smell funky. It gets run pretty much once a day.
Thanks in advance for your ideas.
John
But what is the wash cycle temperature? Maybe it's not hot enough to dissolve everything and you're getting a buildup of gunk. That's my first go to. Second is to be sure the bottom spray arm is actually revolving by opening the door a few times during the wash cycle and looking to see if it's in different positions from the previous.
Yes Mark, you may choose an extra rinse if desired.
Eddie
Super Wash
Normal
Whites
Wrinkle Control
Colors/Jeans
Delicates
Bulky Items
Hand Wash
Enviro Plus
Quick Wash
Spin Only
Well, my neighbor's machine was 13 years old when he got it.
Being in nice physical condition for the price, he wanted it to match his Monogram fridge and Kenmore range, all in that stainless steel face look.
Besides, after spending lots on tearing apart and remodeling the kitchen, it was a small price to him.
As for me, my kitchen's a classic 1970's modern style that I'm happy with.
I'm not one to "buy into" the advertizing hype that many are prone to.
I just want everything to work, and it seems that older appliances last longer.
Have you checked that your hoses are correct? Hot to hot and cold to cold?
I've long speculated that you need a new control board, or better yet a direct drive washer. No more sorcery.
I agree!
I don't know anything about US machines, least of all top loaders, but would it be worth running the diagnostic cycle and checking the timings against the chart (it's a different model in that video, so may not apply anyway), and also using whatever component test options it has (if it has a heating element, don't run that test unless it has enough water in it). Or possibly a factory reset and recalibration, if those options exist and they don't create more problems than they solve?
i have manage to talk to my mom about having the washer check by a service tech i have also put in note incase the tech suggest replacement the huebsch speed queen tc 5 topload washer with matching electric dryer or the maytag commercial grade washer like in this pic by choice i would stick to a top load because i think the washer i have curently is a lemon so far i am lucky its not the pump problem but with my curent washer nbver know what can happen did laundry yesterday and notice around on quick wash the 1:04 marck during fill washer added hot water when at start during sdsensing fill it should start cold and then swtich to selected wash tempatureHB_TC5_Pair_Front-626x1024 (3).jpegIMG_0090 (1).jpg
@gelaundry4ever https://www.maytag.ca/fr_ca/washers...ft.-iec.mvw5035mw.html?originVariantsOrder=WH this is another model i have noted i do not went something that takes 2 hours to do a load if the cycle takes more than 30 minutes it will cause my mom to complain about the cycle lengh i wish they still made old school mechanical timer direct drive washer sold brand new in store If i could convince my mom to look into use refurbish as new fully restrored direct drive washer like this maytag set and would be less costly would be a great helpClassic direct drive maytag.webp
My advice is go for either a used DD or a new TC5 Speed Queen. Keep the dryer if it is a Whirlpool. Whirlpool dryers in my opinion last longer and dry faster than Speed Queen dryers. I considered replacing my MEDC300XW dryer for years with a Speed Queen just because of the name until I came to terms with the dryer simply being better overall. Easier to fix, longer lasting and faster drying. Speed queen dryers while more durable seem to have reliability problems. I've read to many complaints about the heating element and other major parts going after exactly 10 years. Whirlpool dryers are known for going 20-30 years no trouble, and the most critical parts like the belt, heating element, timer and thermostat can be replaced with a few turns of a hex screw driver.
We had a Whirlpool dryer for 27 years and the only thing we ever replaced on it was a roller. Ditched it because the safety switch snapped off and was right around the time I just bought a new SQ washer AWN432. So went and got a speed clean dryer, the top of the line one at that time.
