Tappan Wall Oven Help
nuwash
Member
Dec 24, 2017
20
Fort Wayne, IN
The home we just moved into has this retro Tappan oven. I cannot find a model number on it anywhere, the timer and clock do not work and I would like to either replace them or know of a tip to repair them. Any ideas?
The Model # may be above one of the oven doors on the bottom of the trim above the doors or below the bottom trim [ lay on the floor to see it ] it will not do you much good as almost no parts will be available for this neat oven except maybe a heating element and the light bulbs which are a standard item.
The clock looks like a GE built clock, these are more fixable than many, there used to be many places that would rebuild them if you take it out and send it away with at least $100.
