robinsondm
Hi folks,
After using a digital thermometer to help debug a self-cleaning problem, I decided to check the temperature accuracy of the ovens on my 1966 GE 40-inch P*7 range. I found the main oven holds a set temperature to within plus or minus 7-8°F -- pretty good! However, the side oven temperature fluctuates by about 80ºF (i.e., plus and minus 40°F)!
Two questions: <span style="text-decoration: underline;">Is this normal</span> for the side oven on this kind of range? If not, do I need a new thermostat? And (okay, three questions) if I do need a new thermostat, would anyone have a lead on where to get one? The part is WB21X5209, but it's NLA. I believe the part does occasionally appear on eBay. Thanks,
Dean
Dean
