Thank you Robert
Dryer working like NEW
Hi Jimmy,
Thank you for the book! It details the operation of the compensated control. It is unlike later models in operation. Rather than heating and monitoring the tempterature with a thermostat until a set temp is reached where the timer then starts, it does this: Depending on the timer position (delicate, regular or heavy), the timer is activated until the heating coils turn on. When they are ON, the timer stops. This cycle repeats and due to the increase in drum temperature, the cycling takes more time the longer the dryer runs. Therefore, setting the timer to Heavy results in more cycle repeats so the overall drying time is increased. Very interesting!
I did find one wire that was touching a neighbor wire on the terminal strip so corrected that. Once that was done, everything started to work as designed. The compensated control may have been replaced, as there is no adjustment screw on the unit as expected. I am very happy to confirm proper operation!
Once my water valve arrives for the washer, they will be in perfect working order.
Thanks again Jimmy!
Once everything is working as designed, I will post pics of the washer activator, mini basket, etc.
Mike
