mattywashboy
Well guys, I won the Wilkins Servis Twin Tub that was on Ebay. I organised a pick up and went and got it tonite.
Its in somewhat good condition. Few issues are lack of any pipe or cable work at all, the drain hose was cut off at some point it seems and replaced with a newer alternative which was also cut off...
Also there is no power cable but my housemate can arrange one to be put on in the near future (approx 2030 knowing his timekeeping).
No fill hose at all.
Agitator has snapped at some point and lost a bit of the plastic holding it together, unsure how this will affect it should i get it back to working condition.
All in all the spin can is nice and clean, very little rust around the machine, just what you would expect from a 50 year old machine. The rubber seals around the machine are stiff as is the Lid Release switch on the wash deck.
Also this model has NO HEATER, the light is blanked out and the spin dial just simply has ON/OFF written on it.
Here are some photos, make of it what you will, any advice would be appreciated.
Many Thanks
Matt
First Pic, a happy new owner, if not slightly disgruntled i couldn't be using it tonite haha.
Many Thanks
Matt
