DiamondTiara
- Joined
- Nov 20, 2025
- Messages
- 10
So, I got this Washer a couple months back because my previous washer had a transmission issue. Of all the modern washers I know of it seems to be the most true to the early 2000's and 2010's washers. Even the gauges resemble the 1990's GE washers, so there is some nostalgic element about it.
This machine is very basic. It has 6 cycles. The Drain and Spin cycle would be the most useful one incase of an unbalanced load. I like that it has Manual Water level select, and it has good Temperature Options. It really is "just" a Washer. It isn't particularly exciting, but it has a lot less that can go wrong with it compared to some other Modern Machines out there. I doubt this washer is going to last more than 5 years considering it is a modern washer.
Only con about it other than the fact that it is a modern washer is that it is fairly loud during agitation. GE washers have a habit of being horribly loud, at least the more modern ones.
