The AMKrayoGuy Griddle R.I.P.
daveamkrayoguy
Silver Member
Dec 8, 2010
5,723
Oak Park, MI
I don't know if there may be a small "break" or "burn" (maybe plural) in the heating element, but can it be replaced?
I really think it will be using my non-stick on the stove until I can finally break down and buy new... Yes, the tray is well-beaten hopelessly caked with a decade of grease, but this is laying there from the attempted use, where the temperature in the gauge just went "down, down, DOOWWWWNNNN!"...
-- Dave
How is the heating element attached? Most of them are "crimped" or "cast" into the deck of the grille, and you just can't get it out.
But, there is a thermostat and probably a one-shot thermal fuse in it which could be bad. You should first check the resistance of the heating element and see if it is, really, open circuit before condemning the whole thing.
If the heating element is still a closed circuit, then look into the control.
Funny you should ask...
Yes, as I opened this, I found these wires are crimped on, but easily came unattached:
There are three screws around where the temperature read out is, but I'm unable to get any of them off...
-- Dave
Burns..., corrosion..., all too simple, but--
While one lead was easily crimped back on, the wire for the other got too frayed...
I think I may not have gently handled it, cleaning it off, or in the crimping, I'd failed to handle with a little bit more finesse...
-- Dave
