the highly regarded 12ax712ax7a/ECC83 &c...
are the most popular audio tubes in the world, over 200 types being produced in 40 factories since introduction in March 1948 by RCA (see RCA tube manual RC-15), then shortly after by GE and Sylvania, later Tung-Sol, Nat. Union, CBS-Hytron, Raytheon, &c, followed by European ECC-83. They are essentially 2 x 6av6 triodes, mu = 100, in one tube. 12AU7/ECC82 and 12AT7/ECC81 are medium and low mu but very similar dual-triode tubes, the obsure 12AD7, 12BZ7, 12DF7, 6679, 6681, 6851 &c are also similar types.
High gain, low noise, and low hum, the 12ax7 types gained huge popularity mainly due to preamp use with the original GE Variable Reluctance low output magnetic phono cartridge. The original 12ax7 was found somewhat wanting so the military/industrial 5751 was introduced in 1950, a ruggedized mini 6SL7, and then a more cost effective 12ax7a for consumer (hi-fi) use. The superior Phillips/Miniwatt ECC83 with the precision grid winding of the 5751 and better cathode materials debuted around '52, followed by Telefunken, Mullard, Brimar, Valvo, MOV, Tungsram and other Euro versions. Most higher end US hi-fi mfrs such as Fisher, Scott, McIntosh &c used the Euro produced tubes re-branded with their own logos as they were truly superior (quieter) to the US tubes. The US competitor for the ECC-83 was the 7025, a std 12ax7a with coiled heater to reduce hum, more expensive, most were sold to guitar amp mnfrs.
All currently produced 12ax7 variants are Russian, East Europe or Chinese origin. Among the most desirable vintage variants are generally conceded to be the Telefunken smooth and ribbed plate ECC83 versions along with Amperex (Phillips) Bugle Boy, and the super rare Telefunken ECC803s gold pin, the latter bring over $1000 each on occasion!
