After over a week of cussing, she's back. Maybe not in her original glory, but I did my best to bring her damn close to it.
For starters, I got the transmission and like I posted in the old thread, it came intact with the suspension frame and brake assembly all together. So, easy swap right? Not quite, because the brake ended up being completely seized together with rust. I can't even break it apart with a hammer. So, after taking the assembly back out for like the umpteenth time, having to remove the springs each time which were tedious with the nickel method (tedious but works like a charm), I removed the brake assembly from my old transmission which is in glorious condition because of being preserved in transmission oil over these years. I cleaned it, installed it on the "new" transmission setup, which thankfully shows not a single sign of rust or corrosion, and after some struggle with trying to line the outer tub and seals properly, got everything back together and from that point, it was like spreading butter on fancy toast.
I was half expecting to hear some form of squeak or screech from bearings, but not a peep. I'm so pleasantly shocked and so very happy it's working so beautifully. I put it through the paces, even leaving it filled with water and bleach for a couple of hours to keep an eye on the concrete floor underneath for leaks, but not a drop of oil or water ever once appeared, even inside the cabinet.
So I have a few photos and then compiled all the video clips I made into one single video for all to enjoy.
