The Inglis Sterling washer runs!
turquoisedude
Aug 8, 2007
10,562
I was also determined to test out that Inglis Sterling model H560 washer of mine this weekend. I replaced the burnt out bulbs and did some basic cleaning on Saturday - here's how it looked then:
The tub was still a little cruddy, so I kept on scrubbing. By Sunday afternoon, I was just dying to hook it up for a water test. Moving the 2001 GE washer was a breeze; I needed hubby's reluctant help to get the Inglis in place! Real steel and porcelain make a heck of a difference. Control panel was all lit up nicely as I started the cycle.
Now, how to clean up the tub?
The tub of the Inglis has kind of a rough film and a lot of hard-water scum build up - how can I best remove this? I took off the gunk from the inner tub lid using CLR and a lot of scrubbing.
Also, I would love to make the agitator shiny again - what can I do to restore its appearance?
Overall, I cannot believe how lucky I have been with this washer - it still seems to work fine and there are no leaks!!
I have just got to try some clothes next (and hopefully film that!!).
Fabulous! I love that model my aunt had it under the Whirlpool badge only it had a white light blue tinge surgulater agitator, i would set in the kitchen all day as she washed. But love the bullet cap bakelite model good luck and happy holidays to you and all. Darren k
The agitator is easy----get a can of clear spray enamel.
I use the Rust-O-Leum "Crystal Clear Enamel".
You will need three or four good coats, and let it cure in a dry place a week or so to harden---- and depending on usage you might need to touch it up every few years. Will make that Surgilator look like new!
I like to clean up the tough mineral and rust deposits with Sno-Bowl (thick) toilet cleaner. Just be prepared to rinse it off real well and wear gloves or it will take the skin off of your hands!
Then after all is dry I mask and use Rust-O-Leum spray paint to touch-up those areas that were rusty or chipped----so rust doesn't re-form.
My two shekels.
Cool! Thanks for the tips! I may have to venture into Vermont for the Sno-Bowl but it will be worth it.
How difficult would it be to remove the surgilator? Don't laugh, but the only time I ever took off an agitator was on a wringer washer and it just lifted right off. I am scared to force or break the one in the machine now...
When I go to remove an agitator from an old Whirly/Kenmo I just unscrew the cap,give the top of the block a squirt of PBlaster and using the palm of my hand I give the agitator a gentle whack down towards the skirt. Works for me every time.
Beautiful! Thanks for posting.
Great job on the detailing. The same process of scrubbing should take care of the scale in the wash basket. I've spent many an hour scrubbing Maytag wash baskets with the blue (NOT GREEN) Scotch 'scratchie' pads. A gentle abrasive cleaner (Bar Keeper's Friend or Turtle Wax Chrome Polish) should clean up with some elbow grease. Test in a spot first though before going to town on what ever surface you are cleaning.
Thanks for saving this one!!
Ben
