The Instant Pot: Who Has One/What Do You Think Of It?
frigilux
Mar 3, 2007
12,661
The Minnesota Prairie
I'd been hearing about something called the Instant Pot being all the rage in small kitchen appliances. I figured it was something that would come and go with the holiday gift season. Little did I know it has a widespread and passionate following. Finally saw one used in a cooking video by Phyllis Stokes (of southernfrugal.com). She pressure-cooked collard greens, but noted that it doesn't achieve the same pressure as a dedicated cooker.
A quick Google search uncovered at least a couple dozen Instant Pot cookbooks for everything from American comfort food to Indian cuisine. They appear to come in 3-, 6-, and 8-quart sizes.
Does anyone in the AW family own one of these? If so, is it all it's cracked up to be? I no longer have so much as a slow cooker and started to wonder if the Instant Pot might be a good small appliance choice for multiple applications.
I-Pot
I bought mine about a year and a half ago. I'd owned a Farberware electric pc in the late 80's and it sucked eggs, just awful. I've been pc-ing since the late 70's because I was vegetarian and I liked getting brown rice and beans, etc., so fast. I own stovetop pc's ranging from 1.5 litres to 22 litres, still.
But I've given away all my medium-sized ones because the I-Pot is so much easier. Please, Frigilux, don't go buy one of those crappy imitations with a flimsy aluminum pot covered in nonstick. You'll learn to hate it when that crap starts flaking off--which it will under pressure. Don't be deceived by all those silly buttons on the front of any of these pots; they only do a few things and you only need to use a few of the buttons. For example, the Duo that I have (the 6 qt) has 'chili', 'stew', 'beans', 'rice', 'porridge', and I think a few more. I've never used any of them. The only buttons you need are the slow cook, the saute, and the manual (pressure cook).
The slow cook works perfectly; I've also given away 3 Crock-Pots because I simply don't need them any more. The problem with those slow cookers like West Bend that are just a thin nonstick pot on a hot plate is that food doesn't cook evenly. Believe me, with the very heavy stainless steel pot in the I-Pot it'll cook perfectly. The other great advantage with the I-Pot on slow cooker is that it has three ACCURATE heat settings. So many people have found that with modern slow cookers, that even the low setting will cause liquids to boil. The listed heat settings on my Duo are exactly what the specs say they will be, and you can indeed cook a pot roast at 170F if that's what you want. And, of course, you can set the timer easily for whatever cook time you want and then it'll shift to keep warm for 8 hours or until you turn it off. I've got blackeyed peas in the icebox now that I slow cooked overnight last night; I like the 'soup' they make on slow cook better than pressure cooked. If I'm using them for a cold salad, then I pressure cook them.
I use saute for stuff like roasts; I don't have to dirty a skillet to sear it because there are 3 saute heats and the hot one gets very hot. Again, it's s.s. so you don't have to worry about any coatings or finishes. Then, you can slow cook your roast or whatever in the same pot. I also use the saute function to make fresh iced tea. I dump the cold water in the pot, punch saute at high heat, and it'll beep to let me know the water is boiling. I don't have to watch the pot like on the stove.
Compared to stove top pressure cookers, this pc is much more efficient in its use of the steam that cooks. You only have to put a cup or so in the bottom for most things. I had a rack of St. Louis style pork ribs I wanted to fix for friends coming over last week. I could pick them up at the H-E-B, gave them my favorite pork rub, placed them in a bowl on the included trivet with foil loosely around them. I added about a cup of water, hit 'manual' and adjusted for 40 minutes. It makes no noise while cooking. At the end I did a quick steam release, took out the cooked ribs, gave them a little BBQ sauce, popped them under the broiler for about 5 minutes. I don't nuke or bake potatoes with this I-Pot; I do the same basic technique for about 45 minutes and they're beautifully steamed, whether white potatoes or sweet potatoes. You don't need all those silly 'smart' buttons; you'll remember how much to pc things and just use the manual button and adjust the time accordingly. You can cook pinto/kidney/navy beans in about 45 minutes from dry in the bag. You can cook brown rice in about 15 minutes.
I've got a friend who's been using hers for canning for her family, 45min for pints and 90min for quarts, same as I do in my AA canners.
If you do a lot of slow cooking, it's worth buying the glass accessory lid because you can look inside while stuff if cooking. They also sell a silicone fitted lid for the pot so you can put it in the icebox if you want.
The pot itself is very substantial. Think of it as an excellent heavy-duty stainless steel pot for the stove, only without handles. I've used mine many times for deep frying because the high sides keep splattering to a minimum. In fact, I bought a second pot for mine because I've run more than one thing at a time.
I bought the regular Duo but they make one that you can control from your 'smart' phone if you're so inclined. These posts cost more than some other brands, but you won't regret spending the extra when you see the difference in quality.
There are tons of great videos on YouTube re the I-Pot and their website is also great.
http://
Frigilux--PS
I'm also a fan of Phyllis Stokes; she has the sexiest voice on YouTube.
Here are some pc/I-Pot channels you might want to check out on YouTube:
1) Jill McKeever, Simple Daily Recipes. Now, she and her family are plant-based, live in Austin, but she has some awesome recipes unless you insist on always eating meat. She also put out an excellent book on I-Pot cooking, you can probably buy used on Amazon. I've been watching her since she first came on YT years ago, when she was using regular pc's.
2) Cooking For One - this is a cool channel focused on pressure cooking for one with the Hawkins 1.5 litre pc. Great recipes.
3) Mike Vrobel - also great pc recipes
4) Flo Lum - great I-Pot and PC stuff.
5) Great Chow - guy is a real meat lover, shows great techniques using the I-Pot.
Re what you quote Phyllis Stokes talking about, whether you use low or high pressure generally has no effect on the foods. It's true--these electric pots normally reach around 11 pounds of pressure, whereas the stovetop ones reach around 15. Things take a little longer, not a lot. I still have my original 6 quart Mirro-Matic from the late 70's and it has a 3-sided 'jiggler' where you can use 5, 10 or 15 pounds. I never used any but the 15. Supposedly, the 5 pound setting was for stuff like fish that's really fragile. But then, at only 5 pounds, why pc it at all?
Look up Lorna Sass on YouTube also. Her book, "Cooking Under Pressure" really started people getting interested in pc'ing again after years of being ignored.
I love mine, especially at altitude here where some foods seem to take forever to cook. Any recipe I already have, there is a copycat recipe adapted for the instant pot by others online and I've never had one turn out badly.
Another plus is it blows rice cookers I've used out of the water. I consider myself a capable cook but for some reason stovetop rice just defies me. Rice cookers I have used always make the rice overdone on the bottom, leave puddles on the countertop, and have a larger minimum water requirement than I like. In the instant pot, perfect rice every time and no puddles on the counter, and I can make just one cup, so no leftovers.
Yes, I have the Duo 80  8 qt and I'm very happy with it.  I agree with everything John says above.. The stainless pot is great.  I have a much older Bravetti automatic one as well that I've used for years but it has the nonstick pot which I don't like.  It's starting to wear .
Now that being said.. I wished I had just bought the 6 qt model instead of the 8 qt. . You really have to be making a big batch of stuff with the 8 qt , which can be convenient at times I guess.  I find it's just a bit too big for what I need.  oh well.  I may actually go out and get a 6qt and give this one to my niece.
I've never tried the slow cook function yet.
Don't be fooled by the so called quick cooking times all the time.. Remember those times don't count the time to reach pressure and the time to release pressure..  It can take a good 20 minutes to reach pressure and with the 8qt another near 15 minutes to quick realease the pressure.  All that on top of the cooking time.  Generally though, most everything cooks in 60 minutes or less start to finish.
Funny, I was in Best  Buy today and they had em stacked up down the aisles. It could be a big seller this Xmas.   As well CR rated the IP pretty good.   Definitely don't buy another brand with the teflon coating. The stainless pot in the Instant Pot is actually very nice, seems well built.
petek
Plus, it's a Canadian company! They didn't have the 8 quart when I bought my 6 quart; the Duo hadn't been out long, and the Lux was still being sold. It cost less but the lid isn't as convenient. Now apparently they're making these with all these supposed functions like 'egg cooker'. Just gimmicks, just like the washers and dryers we see.
Frigilux, Frigilux, Frigilux...
This AW.org. We all know there is no such thing as too many appliances. So why ask if this is worth buying?
LOL
Seriously...I've been kind of wondering about these, too. I'm even hearing them discussed favorably elsewhere.
I think I might have had something cooked in one probably a year ago, but I can't be sure. All I know is that it was a new-to-me gadget at the time, and it apparently had a pressure cooker feature. Not long after, I started hearing about the Instant Pot everywhere. (It was probably...er...hot in some circles already, but I live so far out of the modern world when it comes to cooking it takes a while for information about new products to reach me.)
I'll have to try the rice cook function and see if it outperforms my Tfal electronic which cooks any type of rice perfectly.
I saw that there's now an Instant Pot Mini, something like 3 quarts.. I think that would be too small for two people. And I like to have some leftovers.
petek
I have a Tiger and, like yours, the fuzzy logic means perfect rice of every type. I use that instead of the I-Pot.
When using the PC mode, is there a quick-release pressure ability--like a relief valve or do you simply have to wait for pressure to go down naturally?
Thanks for starting this thread.
I have been thinking about one of these.
I am still trying to justify this purchase as I have 3 pressure Cookers, a Stove, and plenty of Pots and Pans.
I don't have many CT appliances so I suppose because this machine can really multi task, I may invest.
Eddie, that's exactly my sentiments.  But with moving to induction last May, I no longer have a pressure cooker.  Although I'm now thoroughly enjoying surface cooking with the induction.   But my CT appliances consist of one crock pot (used to have 2 but gave one to my partner after his died), 2 mixers, and two food processors.  Also my new stove has a slow cook function for each oven.
Friend I visited last weekend has an I-Pot.  He made batch of chili in it.  Was too salty but that's not fault of the I-Pot, LOL.  He had it on keep-warm while we were out for the afternoon and I was surprised to note the keep-warm is much more a "warm" temp than hot.  Seems a little questionable for food safety.
Luigi, my slow cook function has a temperature range of 170 to 300 degrees F.  I think slow cook actually allows for very extended cooking (beyond the 12 hour limit that's programmed into the controller board (unless you change one of the system settings).  I think the convection fan doesn't come on at all either.  I've noticed that convection will cycle on & off to help maintain temperatures in the big oven even when convection isn't selected.  The instruction guide gives a range of times for cooking at various temperatures.  The feature is overtly intended for slow roasting of various types of meats.  I keep forgetting to email KitchenAid and ask them if the function can also be used as a typical slow cooker could be sued.  thus far I've used it to cook about 4 different roasts.  the results are extremely tender and flavorful but not to the point whereby the meat just completely falls apart like my experience is with a slow cooker.  I've raved about the results to my partner and he's looking forward to experiencing a meal with one of these roasts.  I love I can brown the meat in the same pot I'll be cooking the roast in the oven with.  Both ovens have the function.
