A list of machine features:
The range of temperature settings, including Delicate/Silk and Wool/Hand Wash, offer greater, more precise control when washing fabrics.
The glass-sealed, touch-sensor controls are easy to use and highly responsive. They deliver direction with the lightest touch of a fingertip, and then confirm it with a soft tone.
Heavy-duty, reinforced FloodChek® hoses, equipped with solid brass couplers and two layers of braided rayon, eliminate corrosion failure and deliver superior burst strength.
The second hinge is a critical addition that helps resist cracking as well as keeps the stainless steel door properly aligned so it opens and closes smoothly.
The wash basket is made of stainless steel, which is durable, corrosion resistant and nonreactive to fabric and detergents.
At the beginning of a cycle, the washer offers a preset combination of time and temperature, gradually raising the water temperature - as needed - to optimize the level of care.
A water level sensor ensures that the washer uses only the amount of water needeed, so you can expect significant energy and water savings.
The optional pedestal drawer elevates the washer to a comfortable height for loading and unloading, and also an ideal place for holding cleaning supplies and setting a laundry basket.
