Here's one I know you guys have been waiting for. RCA-Whirlpool introduces The Last Word in combination washer-dryers...the 1961 Ultimatic.
Many of the major manufacturers offered washer/dryer combos back in the day from the 1950s into the 1970s, and some (most?) early models were condensing dryers (didn't need venting) that used a cold water spray and heat exchanger to condense the moisture and drain it away. Bendix pioneered them. Lisa Douglas had a Maytag on Green Acres TV show, although Maytag had trouble with theirs, offered owners an exchange for a toploader pair. Whirlpool discontinued producing them under the WP brand but continued Kenmore until 1971. GE also went into the 1970s.This is a fascinating machine. Did this idea really work and remain practical after years of use? It must have had significant drawbacks that resulted in the idea never taking off. How did the dryer function work? I'm guessing based on the "modulated heat" feature that it simply had waterproof heater coils inside the washer tub that would radiate heat into the metal basket as it turned with no air blowers. And as the clothes gradually heated up, the steam was vented off the top of the machine. I also wonder about it becoming a fire hazard based on incomplete lint removal. But I dunno, it would interesting to learn how they did it and why it eventually failed as a concept.
There were options for lower models with a full-porcelain cabinet. Our 1962 WP LJA32VW00 was all-porcelain. It had had the necessary settings of the time -- Normal & Gentle cycles; hot/warm, warm/warm, cold/cold; low, med, high levels; brush filter -- but was far from top-of-line.I believe top of the line top loading agitator washers from both brands in the early 60s would have had porcelain cabinets also.... So they were probably equal. It's just the cosmetics that are different. Could be wrong though. Don't know if they made the combos with all porcelain cabinets. Someone will answer this hopefully
From what a gather, porcelain cabinets were an option. My Whirlpools from 1963 have porcelain tops, but not a porcelain cabinet. Think some Kenmores of the era were the same as well.I just learned something new. I always thought they reserved those porcelain cabinets for the more top of the line models. I wonder why they did that though ? It's not like they used the body of the machine to catch a spinning tub of water, being they were perforated basket washers. Still a cool thing nonetheless.
