Nice Pair!
Hey Mike, your 'new' Maytags sure look great - even in the great shade of Harvest! Typically, from what I've seen/used, if the operator needs to turn off the dryer manually on the '06/'07 series, one would simply just open the door. The door switch would then kill the dryer, then user could add/remove clothes if needed. You would be killing two birds with one stone if you took a look at the switch - I may have a spare.
Slow agitation on the washer: I just brought in a spare 806 for my parents a few weeks ago. The machine had sat outside for quite sometime, and wouldn't agitate to save it's own life. After letting it warm up inside, I noticed that there were flat spots on the rollers, and the slipping grease, well, wasn't allowing the motor to travel on the track. A new set of belts, roller grease and rollers, and she was back in service, ready for a family of 4. Before servicing this issue, make sure that the underside of the washer isn't coated in transmission grease - a little bit is okay, a LOT would be a cause of concern.
I also have some extra aqua washer panels, if needed. Just drop me a line.
Ben
