Well obviously a towel can't be a solution to the leaking pump shaft seal forever, so now that I had a few fun washes in the Youngstown I took apart the pump again. Its a very bad sealing system, they simply compress a bronze washer against a bronze sleeve bearing. When I pressed out the bearing there was even water between the pump base and bearing tube, oy.
The bearing is worn, so tomorrow I'm going to take this bronze sleeve bearing (or bushing) down to my local bearing retailer and see if they can match it up with a new one. I'm keeping my fingers crossed that its a standard bearing.
Here are the parts of the pump...
