The "Mother" of all Maytag Agitator Pullers
rainislandman
Member
Oct 18, 2008
12
An update with reference to my original query posted as
Thread# 19219 "MayTag Washer circa 1970 - Model A806"
The "Mother" of all Maytag Agitator Pullers using a "Macho Rambo" brute force "Take no Prisoners" approach, which won't for the faint hearted (using the California Governor's vernacular) girlie men. ;-)
This approach is the result of an evolution of two prior unsuccessful attempts, basically the combination of fixerman's approach plus bajaespuma 's, requiring minimal physical exertion and pain.
Materials List
Two by Four lumber
4 @ 24 inches
2 @ 7.5 inches
1 @ 3.5 inches
Plywood - half inch
1 @ 7 inches square
Tuna Tin 3 5/16 inches diameter
Bolts
1/2 by 6 inches
Nuts and washers
Chain (2 inch) plus two shackles
Tube 3 inch outside diameter, 6 inches length
(scrounged from a local machine shop)
Iron Pipe
2 by 12 inches
Socks - 5 pair (CostCo bulk variety)
Tools
12 Ton Hydraulic Jack
Radial Arm Saw
Wood Rasp
3/4 Inch Wrench
long 1/4 inch rod
Procedure
Make up Jack stand using the 2x4 lumber 4 @ 24 inches and the
7 inches square plywood with the 2x4 @ 3.5 inches centred and
nailed to it.
Notch out the 2x4, 2 @ 7.5 inches, using the Tuna tin as the layout guide with a Radial Arm Saw, and rasp out the saw cuts to fit the layout.
Assemble with the bolts to make up the agitator clamp.
Take 8 socks, and using the long 1/4 inch rod, stuff one into each opening at the bottom of the agitator, pulling enough
length through so that the toe will act as a buffer between the Jack stand and the inner agitator tub. Then tie the top ends of the socks together and pull up, then install the 3 inch outside diameter tube into the agitator. Next, tamp down the socks to compact as a heat sink for boiling water.
Install the agitator clamp (using another pair of socks to cushion the wood against the agitator shaft), chain shackles, chain, and Jack stand.
Pressurize the jack, until the chains are tight, and stiff resistance is felt by the jack handle. Then pour boiling hot water into the agitator centre tube, using a pipe as a conduit, and keep testing the resistance on the jack handle.
After two kettles (perhaps less) of boiling hot water, and approximately ten minutes (perhaps less), the Agitator should pull up without excess resistance.
Good Lord, it shouldn't take THAT much force to pop the agitator out! Gotta do whach-ya gotta do, though. Let us know if you and the washer survive without any damage, LOL!!
No other method that I tried worked. Using the jack with controlled force, and the heat from boiling water worked like a charm. There was no damage to the agitator nor the tub. The trick was to apply sufficient upward constant force against the tub, and let the boiling water seeping through the sock material loosen the agitator. I'm sure I would have broken something if I had just applied force alone.
The image I posted was after the agitator had lifted off the tapered spline. My only regret was that Maytag didn't build a better washing machine back in 1970, as the tub seal leaked after only 38 years whereas I had expected it to last at least 60 years and more, :-)
Herewith an image of my agitator clamp.
Yep..."innovative" works...I think this guy thinks like me...back in school, I always arrived at the "correct" answer, but the teachers tended to look at me with that "cocked-headed-confused-puppy" look when I told 'em how I got there, yeppers...
so, uhh, if it's that hard to come off, how do you put i
It'll snap right back into place with ease. It's just removing them after 30+ years of exposure to all of the washing elements temporarily welds things together.
